which dizzy do i need???/
i got a '90 STD (d15 dual point)
it needs a new head gasket and an exhaust valve is bad, so i want to make it multiport while i do that.
but im thinking about putting on a sohc vtec head, and then a z6 intake and TB.
but what distributor will i need?
Modified by zcNOS at 3:31 AM 4/1/2004
zc intake manifold wont fit on a sohc vtec head (i assume ur talking about the dual cam ZC) if you stay obd0 you need a 88-91 si or ex distributor. if you go obd1 u need a 92-95 civic si or ex distributor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicLX »</TD></TR><TR><TD CLASS="quote">zc intake manifold wont fit on a sohc vtec head (i assume ur talking about the dual cam ZC) if you stay obd0 you need a 88-91 si or ex distributor. if you go obd1 u need a 92-95 civic si or ex distributor</TD></TR></TABLE>
All correct! You need an ECU too don't forget!
i can get a z6 head, intake manifold, teg TB and dizzy for $150. sound like a good deal?
just need to find a new ECU.
anybody have a sohc vtec ecu?
if your going mpfi, obd0 then you need 88-91 Si or HF dizzy. DX dizzy does not have #1 cyl position sensor in it. you can not modify the z6 dizzy to work obd0. from what ive read, you will also need an adjustable timing gear. id strongly recommend a tranny upgrade also.. the std tranny is a beast
suspendedHatch
10
Dec 4, 2019 11:56 AM
delsol242
Nov 4, 2012 06:20 PM
