question about oem gsr fuel injectors?
Old Mar 21, 2004 | 05:11 PM
gsr2187's Avatar
Default question about oem gsr fuel injectors?
does anyone know if the oem injectors on a 2000 gsr are high or low impedence? i dont have a volt\ohm meter so i have no way of finding out myself. i accidentally ordered low impedence peak and hold type injectors and i dont know if ill be able to use them in my car. any help would be appreciated. thnx.
Old Mar 21, 2004 | 05:47 PM
Kendall's Avatar
They are high impedence and saturated I believe. Use the search function and you can find out much more.
Old Mar 21, 2004 | 06:40 PM
Jim Truett's Avatar
Default Re: question about oem gsr fuel injectors? (gsr2187)
You will be able to use them, but you will need to wire in a resistor box from an OBD-0 Civic or four 10 ohm resistors, one for each injector.
Old Mar 23, 2004 | 03:40 PM
gsr2187's Avatar
Default Re: question about oem gsr fuel injectors? (Jim Truett)
ok thnx, now would it be better to get a resistor box from, say, a civic si or does it matter? also where would be a good place to pick one up?
Evansouders
Jul 30, 2013 05:50 PM
jetspeedz
Jul 27, 2009 07:14 PM
EH3 JR
Feb 11, 2009 12:17 AM
eg8tuner
Apr 14, 2007 06:49 AM
sPaRk'iT
Oct 22, 2003 12:45 PM
