anybody use Kosei K1 racing rims in 15X7 ?
Old Oct 21, 2001 | 05:49 PM
nawoj's Avatar
Default anybody use Kosei K1 racing rims in 15X7 ?
i got some and it is a super tight fit in the rear, and im not talking wheel gap
im talking the clearance between the inner sidewall [and the rim of the wheel] to some suspension parts.
i have 205 tires on there, it suggests 195's but in not really worried about the tire,
the rim of the wheel is really close to the upper arm, and the trailing arm is close [not super close] to the tire.
tell me everything is ok,
or tell me where i can get a wheel spacer to alieviate my problems.
thanks
[Modified by nawoj, 9:56 PM 10/21/2001]
Old Oct 22, 2001 | 02:03 PM
89HF's Avatar
New User
Default Re: anybody use Kosei K1 racing rims in 15X7 ? (nawoj)
Nawoj:
I have 17x7.5" Kosei K1s w/45mm of + offset.This is the most + offset available and puts my wheels (and 17" 205/40 tires) as close to the r trailing arms and control arms as you probably can get,but they don't rub.How much + offset do your wheels have?
[Modified by 89crxb16a, 11:03 PM 10/22/2001]
Old Oct 22, 2001 | 02:42 PM
nawoj's Avatar
Default Re: anybody use Kosei K1 racing rims in 15X7 ? (89crxb16a)
im pretty sure the offset is 45.
after driving with them on today, they do rub on my rear trailing arm.
with your 17" rims you wouldnt encounter the upper arm problem [it would be inside the rim.
im not sure how your not rubbing but thanks anyway.
Brandeezy1
Jun 20, 2012 04:04 PM
APAem1
Sep 16, 2010 12:13 PM
mpxs20
Aug 23, 2005 08:02 PM
mickey513
Mar 30, 2002 06:03 AM
Todd00
Dec 5, 2001 11:59 PM
