What kind of times should i expect from this?
Old Mar 21, 2004 | 03:57 PM
95DXCIVIC's Avatar
Default What kind of times should i expect from this?
b18C with revhard turbo kit... in a 88 crx hf, full interior?? runnin at 15psi
thanx in advance
Old Mar 21, 2004 | 04:01 PM
Fred n J_v2.0's Avatar
Default Re: What kind of times should i expect from this? (shinlou)
Go to the track and run it... That will be the best way to get an answer...
It really depends on driver/elevation/track/slicks or street tires/etc...
Old Mar 21, 2004 | 04:04 PM
95DXCIVIC's Avatar
think ill be able to run 11's with the setup??lets say i was a very good driver and track conditions were above average runnin on slicks 15's, and also its down in south florida
Old Mar 21, 2004 | 04:10 PM
^jefs0ng's Avatar
Banned
I'd say it was possible if you had "the right stuff"
If slicks and motor + turbo were all you had, I wouldn't really bet on it..
Old Mar 21, 2004 | 06:44 PM
ceLtic's Avatar
N/A wh0re!
Default Re: (^jefs0ng)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ^jefs0ng &raquo;</TD></TR><TR><TD CLASS="quote">I'd say it was possible if you had "the right stuff"
If slicks and motor + turbo were all you had, I wouldn't really bet on it..</TD></TR></TABLE>
&lt;3
Old Mar 21, 2004 | 07:40 PM
4inspeed's Avatar
Default Re: (chrism)
here check yourself
http://www.battleoftheimports....c.htm
according to this you need at least 230 WHP to run a 11.9 in a car that weighs 2000 pounds.
there is the e.t. calculator, then again you need a close hp number to use it
2kTeg
Sep 2, 2005 08:45 AM
PTR1
Aug 24, 2004 01:26 PM
dclsvtec
Jun 1, 2004 03:10 PM
dunkd
May 25, 2004 04:11 PM
