Vacuum Manifold with GS-R Backet. More bling-bling than GE.
Old Mar 21, 2004 | 03:01 PM
Mad Cow's Avatar
Default Vacuum Manifold with GS-R Backet. More bling-bling than GE.
First off, let me start by saying that this item is WAY nicer than the GE unit. It's made out of polished aluminum, has tapered threads, and comes with the fittings. The bracket is made to fit on GS-R fuel rail studs. Asking price is $40 shipped with fittings.
Selling for a friend, PM NateTeg95 with any questions. Check HERE for more pictures at every angle.
Old Mar 21, 2004 | 08:21 PM
Mad Cow's Avatar
Default Re: Vacuum Manifold with GS-R Backet. More bling-bling than GE. (MadCow)
Old Mar 21, 2004 | 11:19 PM
turbogeekDA6's Avatar
im very interested. do you only have one? you could sell a ton of these. these mount to the studs on the fuel rail for a b18c, correct? i will definately pick this up this week.
Old Mar 21, 2004 | 11:26 PM
MindEracer's Avatar
I want one! Who do I contact to buy one and were do I send the money!!!
Old Mar 22, 2004 | 12:17 AM
SoSoxGino's Avatar
BANNED
Default Re: Vacuum Manifold with GS-R Backet. More bling-bling than GE. (MindEracer)
$40 Camp1320.com has them for $35
and its more bling nad has more ports
Old Mar 22, 2004 | 07:17 AM
Mad Cow's Avatar
Default Re: Vacuum Manifold with GS-R Backet. More bling-bling than GE. (SoSoxGino)
Your title is very fitting. Nowhere in my thread does it ask for your opinion on where I can get one cheaper or with more ports, and nobody else has this piece. This piece was custom made for Muckman, and he ended up not buying it. He specifically requested a manifold that was small enough to fit under a strutbar, and that had 4 ports plus an inlet. 99% of people have wastegate, blow off valve, boost gauge, and possibly an EBC (hence the extra port that has a plug for later expansion).
For $40 you're getting a custom made piece that nobody else has. It was hade made (as opposed to CNC'd). NateTeg95 makes them not because he makes a ton of money, but because he likes doing it. It takes a few hours of work to make and polish, plus the money for the fittings, plus shipping. If you want one from somewhere else, buy it. If you want an original piece that looks better than any other vacuum manifold you or I have ever seen... Pm NateTeg95 and he'll tell you how he wants payment. He'll be around after 5:30pm today. If there's demand for more than one, he'll make more.
It mounts similar to mine, but the bracket places this manifold closer to the injector wire cover obviously:
Mine was pretty dirty in these pics, it wipes off easily and looks shiny with just a paper towel.
Old Mar 22, 2004 | 09:19 AM
streetlvlhatch's Avatar
Im definetley intersted. Who makes/made it?
Old Mar 22, 2004 | 01:18 PM
M.A.R.C.'s Avatar
Default Re: Vacuum Manifold with GS-R Backet. More bling-bling than GE. (streetlvlhatch)
i like it. too bad i don't have a gsr so i don't think i'd benefit from the brackets if not i'd rock one fo sho
Old Mar 22, 2004 | 02:40 PM
NateTEG95's Avatar
Default Re: Vacuum Manifold with GS-R Backet. More bling-bling than GE. (CivicRyda2k)
I am the one who made this manifold. Lots of thanks to Madcow for making this post he is the one that gave me the original idea. The one in the picture is for sale as is with the fittings. If there is enough feedback I will start manufacturing them on a large scale with our CNC mill. I will also try to make brakets to fit different cars. The GS-R is the only on where it will mount on the fuel rail bolts. So let me know if anyone is interested. Thanks
Old Mar 23, 2004 | 06:39 AM
Mad Cow's Avatar
Default Re: Vacuum Manifold with GS-R Backet. More bling-bling than GE. (NateTEG95)
Yeah, if you LS guys look at your fuel rail studs, they're not vertical like the GS-R studs. Find a place where you want it mounted, and he can sort out a bracket for you.
Old Mar 23, 2004 | 08:53 AM
WalkingKenshin
Guest
Posts: n/a
$15 ?
Old Mar 23, 2004 | 01:23 PM
NateTEG95's Avatar
Default Re: Vacuum Manifold with GS-R Backet. More bling-bling than GE. (WalkingKenshin)
You must be stoned to think I will sell it to you for $15 the fittings alone cost $8.
First to pm me gets it for $40 shipped.
Old Mar 25, 2004 | 01:51 PM
Mad Cow's Avatar
Lots of people talking, but nobody has the cash... bring on the cash.
Old Mar 25, 2004 | 03:28 PM
NateTEG95's Avatar
Come on people who wants it?
Old Mar 25, 2004 | 03:45 PM
Sassafrass's Avatar
Newbie question, but what is its purpose?
Old Mar 25, 2004 | 05:09 PM
specv5150's Avatar
Default Re: Vacuum Manifold with GS-R Backet. More bling-bling than GE. (Sassafrass)
from my understanding it is like a central unit of sorts to plug in your vacuum lines. Instead of running them every which way, you can hook that piece up to a vacuum line and then plug in other hardware that requires vacuum lines (boost, BOV, etc) into the piece for a cleaner install
Old Mar 25, 2004 | 05:19 PM
BlueSi2k's Avatar
Default Re: Vacuum Manifold with GS-R Backet. More bling-bling than GE. (specv5150)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 &raquo;</TD></TR><TR><TD CLASS="quote">from my understanding it is like a central unit of sorts to plug in your vacuum lines. Instead of running them every which way, you can hook that piece up to a vacuum line and then plug in other hardware that requires vacuum lines (boost, BOV, etc) into the piece for a cleaner install</TD></TR></TABLE>
Besides a cleaner install, its also functional. The devices on it will respond quicker because they receive a stronger vacuum signal. When teeing off a million times you lose this strength. The inlet on these use a bigger diameter to provide a better source.
Old Mar 25, 2004 | 05:47 PM
rtype11's Avatar
me see me like, me bump!
Old Mar 25, 2004 | 06:42 PM
specv5150's Avatar
Default Re: Vacuum Manifold with GS-R Backet. More bling-bling than GE. (BlueSi2k)
good point..wasnt aware of that...to bad I odnt have a GSr either
Old Mar 25, 2004 | 06:48 PM
rtype11's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 &raquo;</TD></TR><TR><TD CLASS="quote">good point..wasnt aware of that...to bad I odnt have a GSr either </TD></TR></TABLE>
just buy it and redrill the holes when you get it to fit your app.
Old Mar 25, 2004 | 07:24 PM
Flamenco-T's Avatar
Default Re: Vacuum Manifold with GS-R Backet. More bling-bling than GE. (rtype11)
very very nice..!! it look so good and clean, I really like it...
stan
Old Mar 25, 2004 | 07:28 PM
B18Flip's Avatar
wow thats pretty hot!
Old Mar 26, 2004 | 07:01 AM
Mad Cow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtype11 &raquo;</TD></TR><TR><TD CLASS="quote">me see me like, me bump!</TD></TR></TABLE>
See, I knew we could be friends. Thx for the bump.
Find a place where you want to mount it, measure the two studs/bolts/whatever and their distance apart. PM measurements to NateTeg95 or post here, and he'll make you one. He'll probably want a $5 deposit prior to him custom fab'n the bracket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">very very nice..!! it look so good and clean, I really like it...
stan</TD></TR></TABLE>
Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Flip &raquo;</TD></TR><TR><TD CLASS="quote">wow thats pretty hot! </TD></TR></TABLE>
Thanks!
Old Mar 30, 2004 | 03:21 PM
FragSyndrome's Avatar
would you sell it for 30 shipped without the fittings? I already have the fittings.
Old Apr 22, 2004 | 07:11 AM
kcjohnnyboy's Avatar
i'll buy it if you still have it for sale?? p/m me..
