Swap Help (engine dieing out of nowhere)
This weekend i swapped in a D16Z6 in my (93)EG hatch and did the auto-manual conversion. I'm using a P06 ECU for the time being with the VTEC solenoid not wired.
Now heres the problem:
The engine cranks and starts fine. It seems to have an erratic idle (from what sounds like 700-1300rpm). The engine itself will idle for an undefined time and then it will just "die". There is nothing causing this dieing and everytime it dies at different points in time. The car can be driven but whenever you stop to idle, the car shuts off.
I seem to throw CEL code 4 (04 Crankshaft Position sensor.. Fix: Timing belt slipped, defective CP sensor). The Dizzy has been changed with one that was working on a different time. We checked all the sensors with a voltmeter as well as the wiring from the dizzy and everything is to spec.
Edit: Does anyone know what else I could check to make this work? I NEED my car.
despat
14
Dec 23, 2009 06:30 PM
memorybox
10
Nov 19, 2006 01:42 PM
