So I installed kyb agx's and eibach springs today
Old Mar 21, 2004 | 01:28 PM
thehondaguru's Avatar
Default So I installed kyb agx's and eibach springs today
And for some reason the front end of the car sits higher than the back. What the hell is up with that? They ride very nice but it sits realy ugly. I am didspointed.
But I was a little confused while doing the install. The damper fork has no place to sit on the shock like the stock ones. So I had no clue where to tightn it down at. Should I have let it sit against the brackets for the brake lines? Because I didnt do that. I just had a little bit of the shock showing out of the bottom of the damper fork. I am thinking that could be the problem.
Any input of this would be great!
Also what would be good to use to get my ignalls camper kit to stop squeeking?
THANKS GUYS AND GALS
Old Mar 21, 2004 | 01:35 PM
Mykizism's Avatar
Default Re: So I installed kyb agx's and eibach springs today (95 lude)
the kyb agx's do have a notch where the fork is suppost to be be tightned around like the stock shocks, i would go back and check the front shocks to make sure they were installed correctly
and as for the car stance, i would double check the shock install, did you cut the bump stops around the car? , and u sure u got the springs in the right place?
Old Mar 21, 2004 | 02:52 PM
Chief Brody's Avatar
Do it right the first second time!
Community Builder
Active Streak: 30 Days
pictures? is it THAT bad? if you go through and check it out and everything is fine... you might want to let it settle for a while.
Old Mar 21, 2004 | 04:21 PM
Default Re: So I installed kyb agx's and eibach springs today (92prelude)
Its pretty bad. I also noticed my drivers side rear is ALOT lower than the other side. I dont get it I havre done suspension like 5 other times and never had a problem, now I do it on my car and it lookd like ****.
The only thing the shocks had was an indentation on the shock but it didnt line up to where it would mount with the brake lines. I mean I double checked everything and its right. I have the rears set at 4 and the fronts set a 3 and they ride nice its just it doesnt settle right.
Its dark otherwise I would take some pics
and as for the car stance, i would double check the shock install, did you cut the bump stops around the car? , and u sure u got the springs in the right place?[/QUOTE]
I done knowwhat you mean cut the bump stops? I used the energy suspension peices for the top of the spring. I mean you really cant mess up suspension.
Old Mar 21, 2004 | 04:43 PM
This is really bugging the hell out of me I need to figure out why the hell it looks so bad. I have never seem a car look wors after some new shocks(I already had the springs).
Old Mar 21, 2004 | 04:59 PM
Daboi630's Avatar
just out of curiousity what springs are they? sport or pro?
Old Mar 21, 2004 | 05:00 PM
Behan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 lude &raquo;</TD></TR><TR><TD CLASS="quote">The only thing the shocks had was an indentation on the shock but it didnt line up to where it would mount with the brake lines. I mean I double checked everything and its right. </TD></TR></TABLE>
you're talking about the fronts right? you put the shock on the wrong side, i did the same thing at first, but realized it was wrong when the brake lines didn't bolt up. there is a marking on the brake line bracket that says R or L. double check that.
Old Mar 21, 2004 | 05:16 PM
Sicc Mugen's Avatar
i notice that too,when i install a tein suspenion on my 5 gen lude. everything is set up right and the driver side sit lower then the passenger, i guess most of the weights lean to the driver side dont know ..........................
Old Mar 21, 2004 | 07:06 PM
Default Re: So I installed kyb agx's and eibach springs today (Sicc Mugen)
I will double check that but I am pretty sure I put them in right. I crossreferanced the part #'s before I did them and then the shocks do say right and left on them. The brake lines lined up perfectly.
The springs are eibach pro. I had them on the car for about 40,000 miles with the oem shocks and decided to swap the with the agx's and now I am pissed because the car lookas horrible. I mean every wheel well is at a different height.
The back ones are totally unable to mess up I mean its easy as hell and the left side sits lower than the right and the fronts are higher than each of the rears.
Now I did the fronts before even pulling out the rears so I know I didnt put the rears in th efront on accident. Like I said I made sure I had the right ones on each spring.
Thanks again for the help so far!
Old Mar 21, 2004 | 07:25 PM
4thgenlude's Avatar
all I can think of is that maybe you put the shocks in the wrong places, but it sound slike youre pretty sure there all inthe right places, I dunno call up KYB and see what they say
Old Mar 21, 2004 | 07:47 PM
99spanishGT
Guest
Posts: n/a
Default Re: So I installed kyb agx's and eibach springs today (4thgenlude)
maby one of the backs is in the front if one corner is sitting higer than all the others!
Old Mar 21, 2004 | 09:11 PM
Daboi630's Avatar
let us now what the problem is.
i have a set of sportline and wanting to get some AGX. just hopin to not run into the same problem as you did.
Old Mar 21, 2004 | 09:18 PM
Mykizism's Avatar
i dunno, my old set up used be eiback prokit with AGX, and my car was even all the way around... shrugs
i would double check the fronts tho.. b/c the agx do have a notch where its suppost to be lined with the fork
Old Mar 21, 2004 | 09:30 PM
solowerks's Avatar
ok I didn't read the whole post, so if somebody said this already don't flame me!
Maybe you put the springs on backwards. The front springs rates are higher than the rear due to the extra weight.(motor) Friend of mine did this also and his car rode higher in the front than the rear because he put the 350lb springs in the front and the 250 lb springs in the rear.
Old Mar 22, 2004 | 02:14 AM
Default Re: (solowerks)
thanks for the sugestions but I could not have put the rears in the front because the rears are atached diredtly to the rear knuckle assembly, and the fronts have to be attached to the damper fork to be put in.
So I know I did that right.
I dont know what the hell is wrong
Old Mar 22, 2004 | 02:37 AM
Behan's Avatar
Default Re: (95 lude)
well if you are certain everything is installed correctly, then i would say you have a set of faulty shocks. call kyb or the distributor you got them from and explain your situation. good luck
Old Mar 22, 2004 | 04:06 AM
Tad's Avatar
Tad
just a REAL quick note,
the further you shove that shock into the fork, the lower that corner of your car will be
so if you only put it in alittle in the front, thats why its higher.
just shove it down further and you'll be set.
you want to make sure it cant slip tho, cuz if it shoves down all the way or something while driving that'd be bad
a note.. this method of lowering is nice cuz it doesnt hurt suspension travel at all.
Old Mar 22, 2004 | 09:03 AM
Behan's Avatar
Default Re: (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">just a REAL quick note,
a note.. this method of lowering is nice cuz it doesnt hurt suspension travel at all.</TD></TR></TABLE>
there is an indentation on the shock that lines up with the bolt for the damper fork.
Old Mar 22, 2004 | 11:26 AM
Default Re: (Behan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Behan &raquo;</TD></TR><TR><TD CLASS="quote">there is an indentation on the shock that lines up with the bolt for the damper fork.</TD></TR></TABLE>
Yeah I need to double check that. Thats the only thing I didnt check.
On a good note my rear shock finally settled all the way and the back is now even. So I just need to figure out why the front is so high, but I am willing to bet its the bolt not in the notch I am a retard!
Old Mar 22, 2004 | 01:25 PM
-Midnight-'s Avatar
just so u know i have kyb agx adjustable shocks all around and eibach pro-kit springs in my 5gen and there are no problems, the car looks very even- however i did cut the stock bumpstops the way eibach reccomended.
Old Mar 22, 2004 | 02:13 PM
slowsh's Avatar
Default Re: So I installed kyb agx's and eibach springs today (-Midnight-)
i have Tein S tech and kyb agx. and my rear is lower than my fornt. its a 1inch difference
Old Mar 22, 2004 | 03:35 PM
Default Re: So I installed kyb agx's and eibach springs today (slowsh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowsh &raquo;</TD></TR><TR><TD CLASS="quote">i have Tein S tech and kyb agx. and my rear is lower than my fornt. its a 1inch difference</TD></TR></TABLE>
That sucks
How are the bump stops suposed to be cut? Never heard of that
Old Mar 22, 2004 | 03:41 PM
Community Builder
Search for "bumpstop".... some springs tell you now to cut them, some tell you you should. I didnt have to cut mine with H&R.... im pretty sure you do with eibachs.
Old Mar 22, 2004 | 03:47 PM
ok I'll search
Old Mar 22, 2004 | 03:57 PM
Um I didnt really get much. I used the energy suspension ones and really dont want to cut the bumpstops. I honestly dont see any purpose
