Help! Engine Code on a ZC...
Old Oct 21, 2001 | 05:13 PM
606zc's Avatar
New User
Default Help! Engine Code on a ZC...
Here's the situation...
I've got a ZC with a 89 integra ecu. I cleaned my engine bay and covered certain parts (battery, intake, alternator, distributor) to prevent them from getting wet. After I was done cleaning, I started up the engine and my A/F gauge was reading extremely lean. After about minute or two, my check engine light came on and my ecu was throwing a 1 code. I reset my ecu, but the same thing occurs.
Can anybody help? Does anyone know where I can get the engine codes for a 89 'teg ecu? Did I fry my O2 sensor? Any suggestions are greatly appreciated!
Thanks everyone!
Old Oct 21, 2001 | 05:49 PM
Hondasaurs's Avatar
Default Re: Help! Engine Code on a ZC... (606zc)
I had the same problem with my ZC swap. The check engine light kept comming on with a code 1. I started using higher octane fuel (93 octane). After about 100 miles or so the engine ran smoother and the light never came back on.
Old Oct 22, 2001 | 07:20 AM
EP3_05's Avatar
I had the same code when I did my zc swap. I rewired and replaced my O2 sensor and that got rid of it for good.
Old Oct 22, 2001 | 09:56 AM
606zc's Avatar
New User
Thanks for the suggestions so far. I probably replace the 02 sensor this week. Anyone else have other ideas on this problem?
[Modified by 606zc, 6:57 PM 10/22/2001]
Old Oct 22, 2001 | 10:34 PM
976's Avatar
976
New User
MIL Code 1:
Primary Heated Oxygen Circuit
-Open or short in Primary HO2S sensor
-Primary HO2S sensor
-ECM
messeduprex
Sep 5, 2003 06:46 PM
CWBETB
May 29, 2003 07:54 PM
speedfreak420
Jul 3, 2002 12:57 PM
606zc
Oct 22, 2001 03:48 PM
