Help! Engine Code on a ZC...
Here's the situation...
I've got a ZC with a 89 integra ecu. I cleaned my engine bay and covered certain parts (battery, intake, alternator, distributor) to prevent them from getting wet. After I was done cleaning, I started up the engine and my A/F gauge was reading extremely lean. After about minute or two, my check engine light came on and my ecu was throwing a 1 code. I reset my ecu, but the same thing occurs.
Can anybody help? Does anyone know where I can get the engine codes for a 89 'teg ecu? Did I fry my O2 sensor? Any suggestions are greatly appreciated!
Thanks everyone
Thanks everyone
sounds like the o2, check http://www.geocities.com/hondacivic4g under info, go to the bottom all the codes are there.
Thanks for the help guys. It sounds like the consensus is the O2 sensor. Hmmm...anybody have any other ideas before I replace o-so-expensive O2 sensor?
yeah buy a oem honda one.aftermarket ones do not go well with the ecu.trust me i learned the hard way and that is straight from the mouth af a honda mechanic.just fork over the extra bucks and this way you don;t have to worry about it.
speedfreak420
Jul 3, 2002 12:57 PM
