anyone out there got a full spec list of the s2k?
i'm really considering geting an s2k now since my car is wrecked now (lady rear ended me on the freeway, and made me do a good 200-225 degree spin on the freeway, damn near killed me) i tried searching for "s2000 specs" "s2000 specifications" "s2k specs" "s2k specifications" etc...but i'm looking for something like this:
Engine :
Type - 4 in line, aluminum block n' head
Bore x stoke - 3.19 x 3.05 in , 81.0 x 77.4 mm
Displacement - 97 cu in, 1595cc
Compression Ratio - 10.2:1
Engine control system - Honda PGM-FI with port fuel injection
Emissions controls - 3 way catalytic converter, feedback air fuel ratio control, EGR
Valve gear - belt driven double overhead cams, 4 valves per cylinder, hydraulic lifters, variable intake and exhaust timing and lift
Power (SAE net) - 160 bhp @ 7600 rpm
Torque (SAE net) - 111 lb-ft @ 7000 rpm
Redline - 8000 rpm
Drivetrain :
Transmission - 5 speed manual
Final drive ratio - 4.40:1
Gear Ratio MPH/1000 rpm Max Test Speed
I 3.230 4.8 38 mph (8000rpm)
II 2.105 7.3 58 mph (8000rpm)
i'll cut it off there, you get the picture....but after that there's:
dimensions and capacities
chassis/body
interior
suspension
steering
brakes
wheels and tires
and then test results
its a car and driver format, but they no longer have it on their website...anyone have it?
Engine :
Redline - 8000 rpm
Drivetrain :
chassis/body
interior
suspension
steering
brakes
wheels and tires
what exactly are you looking for? the spec list for the older s2ks? If you can get an older s2000 catalog, the whole thing should be listed in the back
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SimbaDogg »</TD></TR><TR><TD CLASS="quote">ohhhh man. i'd love you for it</TD></TR></TABLE>
lol, no need for homosexual tendencies, once I'm through with finals, I'm sure it'll turn up so be patient.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor »</TD></TR><TR><TD CLASS="quote">
hey hey hey...easy now...i dont do that shiet. i'm talkin about a spiritual thing man....like how a father loves a son...
</TD></TR></TABLE>hey hey hey...easy now...i dont do that shiet. i'm talkin about a spiritual thing man....like how a father loves a son...
thanx for all the help guys. i was pretty much able to piece a lot of stuff together...but still, a lot of stuff was missing. anyone have these figures:
DRIVETRAIN:
Transmission - -Speed w/Torque-Sensing Limited-Slip Differential
Final drive ratio - 4.10:1
Gear . Ratio .MPH/1000 rpm .Max Test Speed
I .3.133 .x .x
II .2.045 .x .x
III .1.481 .x .x
IV .1.161 .x .x
V .0.971 .x .x
VI .0.811 .x .x
ACCELERATION
Zero to 30 mph ..
40 mph .
50 mph .
60 mph .5.8
70 mph .
80 mph .
90 mph .
100 mph .
110 mph .
120 mph .
Street start 5-60 .
Top gear acceleration 30-50 mph .
50-70 .
Standing Ό mile .14.2@ 98.1 mph
Top speed .
INTERIOR SOUND LEVEL
Idle .
Full Throttle Acceleration .
70 mph cruising .
70 mph coasting .
DRIVETRAIN:
I .3.133 .x .x
II .2.045 .x .x
III .1.481 .x .x
IV .1.161 .x .x
V .0.971 .x .x
VI .0.811 .x .x
ACCELERATION
Zero to 30 mph ..
40 mph .
50 mph .
60 mph .5.8
70 mph .
80 mph .
90 mph .
100 mph .
110 mph .
120 mph .
Street start 5-60 .
50-70 .
Top speed .
Idle .
70 mph cruising .
70 mph coasting .
SuzukaBlueAP2
Honda S2000
49
Jul 28, 2004 07:14 PM
