VX block Z6 head setup. Z6 timing belt was to loose... someone help?
Old Mar 21, 2004 | 11:08 AM
JSPECHB's Avatar
Default VX block Z6 head setup. Z6 timing belt was to loose... someone help?
I'm using the VX block because I'm going to boost it (low compression pistons) and I'm using my Z6 head. My Z6 timing belt is only like 2 days old and was on my A6/Z6 setup. I'm trying to use it with the VX/Z6 setup and the ****** is way to loose even with the tensioner fully tight. Is this the right timing belt I'm using?
Old Mar 21, 2004 | 11:26 AM
JSPECHB's Avatar
Aight what the hell. Can someone help me out?
Old Mar 21, 2004 | 11:54 AM
JSPECHB's Avatar
Well I found out whats wrong. The belt tensioner on the A6 block is bigger than the one on the Z1 block. So I'm guessing I would use the 1.5 timing belt? Can someone clarify this **** for me.
Old Mar 21, 2004 | 12:11 PM
JSPECHB's Avatar
C'mon wtf. TTT
Old Mar 21, 2004 | 02:33 PM
JSPECHB's Avatar
Default Re: (JSPECHB)
ttt again!!!!!!
Old Mar 21, 2004 | 05:04 PM
nikitad's Avatar
You are the pioneer. Do it, and you'll be the Z1 Timing Belt Guru.
Old Mar 21, 2004 | 05:12 PM
Bserieskllr's Avatar
it should be the right one when you do a head swap your supposed to use the timing belt that matchs the head which is z6 and thats what you got i dunno what the problem is try a vx timing belt though.
Old Mar 21, 2004 | 07:52 PM
EG8R's Avatar
Default Re: (Bserieskllr)
I would not use that belt. Get one meant for a VX.
Old Mar 22, 2004 | 08:28 AM
JSPECHB's Avatar
The Z6 belt is loose as ****. I'm gonna just use the VX one.
The VX belt tensioner is mad small compared to the A6 one. I tried putting the A6 tensioner on the VX block, but didnt work. The mounting bracket is different. So to sum it all up, whats everyone think? VX or Z6 timing belt?
My setup:
D16Z6 Head
D15Z1 Block
Old Mar 22, 2004 | 04:04 PM
JSPECHB's Avatar
ttt
Old Mar 22, 2004 | 06:08 PM
BlueCrxNC's Avatar
Use the VX timing belt. I have a JDM D15B Vtec which is essentially a VX Block mated to a Z6 head.
Old Mar 23, 2004 | 11:51 AM
JSPECHB's Avatar
Default Re: (BlueCrxNC)
Sweet. Thanks bro.
Old Mar 31, 2004 | 12:15 PM
JSPECHB's Avatar
Ok well WHAT THE ****. I finally get the car street legal today and when I start the car I hear a slapping noise. My BRAND NEW timing belt is ultra loose. What the ****! It was nice abd snug when I put it on. The tensioner is all the way tightened. I dont know what to do.
Can someone help me out with what might be wrong!!?
Old Mar 31, 2004 | 04:25 PM
BlueCrxNC's Avatar
When you first put the timing belt on, it's tight, but after it rotates a few times the slack in hidden areas 'shows' up. You're supposed to rotate the pulleys a number of times to take this slack out then re-adjust. Says it in the Helms manual
I don't know what to do if you put the tensioner all the way tight... something isn't right about that. Are you sure the belt you have is the VX belt? How many teeth are on it?
Old Mar 31, 2004 | 08:26 PM
JSPECHB's Avatar
I fixed it dude. Thanks for the help. I had to rotate the crank to get the slack out then tighten the tensioner.
sohchatch
Dec 26, 2020 11:32 PM
Contender25
12
Sep 12, 2011 01:36 PM
jrod95cpe
Feb 23, 2009 12:45 PM
ef-hatchcrap
Feb 21, 2008 04:35 PM
bigwill_2004
May 28, 2007 08:24 PM
