Should I go with plain out H22 or H23 bottom with H22 head?
Old Mar 21, 2004 | 10:24 AM
totalfxaccord's Avatar
Default Should I go with plain out H22 or H23 bottom with H22 head?
I was wondering should I go with just an h22 engine or H23 block, basically the whole bottom end with an H22 head b/c I wanna go with boost later,Probably a T3/04 or highest but Im not 2 knowledgable on the h22 swap, and what internals should I be using, Im wondering If prelude type-s pistons would work?Pllz help me?
Old Mar 21, 2004 | 11:21 PM
chameleon's Avatar
Default Re: Should I go with plain out H22 or H23 bottom with H22 head? (totalfxaccord)
hmm where should i start. first learn what an engine is before you decide to go boost. you can acquire an actual H23A which is h23 bottom end with a h22 head which comes in the accord wagon in japan, might be tuff to find but if you do find it then to ya, otherwise just get a H22A, its not worth all the work of getting a h23 bottom for a minimal gain esp when h22a's are cheap already.
if you have the $ to burn then sleeve the bottom end, get 9.5 JE pistons and some crower rods and you will be set for boost. prelude type s pistons will work, but why?
Old Mar 22, 2004 | 07:27 AM
Default Re: Should I go with plain out H22 or H23 bottom with H22 head? (chameleon)
well see I found an h23 for free cuz the prelude is totally wrecked!
Old Mar 22, 2004 | 11:26 AM
Kal's Avatar
Kal
If you plan on making a h23vtec... i suggest you read up on the thread in the prelude forum. There is plenty of information there.
Old Mar 22, 2004 | 03:28 PM
Sam1am26's Avatar
If you can get an H23 for free than it is totally worth building an H23 Vtec... I would do a LOT of research first...
Start here...
https://honda-tech.com/zerothread?id=510617
h22silvia
Apr 2, 2007 10:28 AM
92prelude_driver
Feb 18, 2007 12:32 PM
teamitr
Sep 19, 2005 04:23 AM
my9thtry
Apr 25, 2005 10:12 AM
