what can fix squeeky doors?
Take it down to one of those garages, midas, autzone.....they usually have all sort of lubricating grease, spray & such....My hood latch wouldn't move so i took it down and they lubed it up, works great for me.
if it squeaks because of the latches....jus lube it up with some wd40...works great...unless some place will do ur dirty work for ya for free and ur lazy as all hell...then do it that way
i used almost 1/4 a can of WD40 on my rear doors (it was the metal piece that connects the door to the frame, not the latches)......now their hella silent........
to keep it from squeeking again, make sure u open those doors every once in a while, even if u dont need to use them......that way keeps everything well moving and lubricated
Hate to bust anyone's bubble, but WD40 is only a bandaid. OK lubricant for temporary measures, but use real oil (penetrating oils work great to get to tight spots) or grease if you want the lubrication to last a while. WD40 will evaporate quickly compared to a quality lubricant.
kkulseth
Jun 26, 2007 07:21 PM
Jonathan_ED3
Jan 12, 2005 01:37 PM
