5 Lug on an EF
Old Mar 21, 2004 | 08:33 AM
kshymkiw83's Avatar
Default 5 Lug on an EF
I looked around and didn't find too much of anything. I just bought a 89 DX Civic. I was looking at putting a 5 lug setup on the car. What would be required to complete this setup?
For the front i don't think too much is needed
But the rear is what i am worried about. Has anyone done this setup before? And if so what all do i need to complete this.
Old Mar 21, 2004 | 08:38 AM
bardo's Avatar
Default Re: 5 Lug on an EF (kshymkiw83)
i know someone on here has done a nice 5 lug conversion on his EF...w/a nsx brake set up...and another memeber has done a 5 lug conversion on his crx w/a spoon brake set up....there on here somewhere with pics as well
Old Mar 21, 2004 | 08:51 AM
kshymkiw83's Avatar
i'm lookin at doing the 5 lug set up with Spoon Calipers and the JDM 16" ITR rims. I hope someone knows what is needed for this
Old Mar 21, 2004 | 08:55 AM
bardo's Avatar
thats what im saying someone has done that on here...do a search you'll deff find it
Old Mar 21, 2004 | 09:00 AM
EG8R's Avatar
Default Re: 5 Lug on an EF (bardo)
I know the rear is pretty much a straight swap! heh
Old Mar 21, 2004 | 09:04 AM
kshymkiw83's Avatar
Default Re: 5 Lug on an EF (skelly ed6)
i did a search and found like nothing.......i guess i'll keep searchin
Old Mar 21, 2004 | 09:08 AM
1's Avatar
keep searching. make sure you click 'archived content'.
https://honda-tech.com/zerothread?id=207764
Old Mar 21, 2004 | 09:14 AM
kshymkiw83's Avatar
Default Re: 5 Lug on an EF (1)
DOH, keep forgetting to click the Archived content thanks alot.
Next question i got on tap is D16A6 Turbo Setups? What kind of number can people put down with a decent A6 Turbo Setup?
Old Mar 21, 2004 | 10:12 AM
Markis.'s Avatar
Get your hands on a integ TYPE R. Take everything off of it and put it on yours. Thats what i did i drive a 89 hatch and i got everything from a 96 gsr. But since TYPE R's are 5 lugs it a be an easy converstion cause everything bolts rite up like it did for me when i did it with the GSR. good luck
Old Mar 21, 2004 | 12:18 PM
lonnieboost's Avatar
Default Re: 5 Lug on an EF (HoodsiR)
here you go
Old Mar 21, 2004 | 12:44 PM
B2FiNiTY's Avatar
Default Re: 5 Lug on an EF (lonnieboost)
dayam...
Old Mar 21, 2004 | 12:58 PM
R6Boy69's Avatar
Default Re: 5 Lug on an EF (B2FiNiTY)
An old pic of my car
Old Mar 21, 2004 | 01:21 PM
kshymkiw83's Avatar
Default Re: 5 Lug on an EF (crXBoy69)
is it worth installing it or is it too much of a hassle and really didn't help out too much?
Old Mar 21, 2004 | 01:57 PM
^jefs0ng's Avatar
Banned
Those white ITRs look like *** on a crx
Old Mar 21, 2004 | 01:59 PM
FourthGenHatch's Avatar
Default Re: (^jefs0ng)
I don't understand why some company just doesn't make hubs with 5 lugs that bolt up like stock. It would be so easy. Or why can't you just get stock hubs like redrilled for 5 lugs.
Old Mar 21, 2004 | 02:08 PM
.nate's Avatar
Default Re: (FourthGenHatch)
A ITR suspension swap is done for way more then just 5 lugs.
Old Mar 21, 2004 | 08:43 PM
kshymkiw83's Avatar
Default Re: (.nate)
but would it really be that beneficial for the 1200-1500 dollars it would cost to do the whole swap, not to mention you then get into the issue of rims to choose from, most companies don't make a 5x114.3.
The more i am thinking about this the less i am getting motivated to do it
Old Mar 22, 2004 | 03:03 AM
Default Re:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kshymkiw83 &raquo;</TD></TR><TR><TD CLASS="quote">most companies don't make a 5x114.3.
I disagree. I believe that is the same bolt pattern mostly all new Hondas and Acuras use, I think the RSX does use that and I doubt anyone out there is having trouble finding rims for their RSX.
Old Mar 22, 2004 | 09:19 AM
kshymkiw83's Avatar
Default Re: Re: (FourthGenHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch &raquo;</TD></TR><TR><TD CLASS="quote">
I disagree. I believe that is the same bolt pattern mostly all new Hondas and Acuras use, I think the RSX does use that and I doubt anyone out there is having trouble finding rims for their RSX.</TD></TR></TABLE>
Is that what the new RSX is running? I wasn't aware of that.
Old Mar 22, 2004 | 09:20 AM
^jefs0ng's Avatar
Banned
Default Re: Re: (kshymkiw83)
Is that what the new RSX is running? I wasn't aware of that. </TD></TR></TABLE>
All honda 5 lug and most all other 5 lug cars are 114.3
Old Mar 23, 2004 | 02:14 AM
kshymkiw83's Avatar
Default Re: Re: (^jefs0ng)
I just didn't know that Honda switched over to the 5 lug on most of their new cars.
Old Mar 23, 2004 | 04:49 AM
Charlie Moua's Avatar
I was going to do this on my ef a while back... I have forgotten the parts that I need.
the rear bolts on no problems, just make sure you get DA brake cables if you have a EF hb. Also make sure your able to connect the brakes lines properly.
the FRONT... I belive you need 94+ outer tie rods arms and a good camber kit cause it will have positive camber.
Old Mar 23, 2004 | 07:28 AM
Driven's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kshymkiw83 &raquo;</TD></TR><TR><TD CLASS="quote">is it worth installing it</TD></TR></TABLE>
Nope.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">or is it too much of a hassle</TD></TR></TABLE>
just finding the stuff, then shelling out the money.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> and really didn't help out too much?</TD></TR></TABLE>
brakes help, if you race it. otherwise, on the street, my 9.5" brakes and 4 lugs work just as good as someone's 11" brakes with 5 lugs.
Old Mar 23, 2004 | 07:46 AM
ApexiChild's Avatar
Default Re: 5 Lug on an EF (Driven)
kinda off topic but worth a shot:
Teins SS on a ef hb...
when i do itr 5lug do i have to worry about anything with the ITR brakes not bolting up to my Tein SS made for the EF?
Old Mar 23, 2004 | 09:13 AM
joesefcivic's Avatar
yes cause the rear control arm is different! i have a type r control arm on my hatch and works awsome same length and all!
