Stock intake box vs Aftermarket intake (cold/short ram)??
Old Mar 21, 2004 | 08:12 AM
mrtrex's Avatar
Default Stock intake box vs Aftermarket intake (cold/short ram)??
Set up b16b in 98 hatch i/h/e Driving style autocross and up/downhill events. Any opinions tests ect.. From what I noticed Spoon sports uses a stock intake set up with a high flow filter but this is the only company that uses this from what could find.
Old Mar 21, 2004 | 08:19 AM
Kendall's Avatar
Honestly, you'll have better results with an aftermarket intake.
Old Mar 21, 2004 | 08:31 AM
zad5's Avatar
Default Re: (Kendall)
damn it i was looking around for what spoom said once but cant find it o well basically they said that the stock system is pretty good. they just changed the filter but if you modify the box (mugen, comptech ice box) then you mite get some powaA.
This is from austin's itr.
Blue=Mugen
Red=Comptech
Parts Installed:
HyTech header
HyTech exhaust
HyTech high flow Renault cat
Mugen headgasket
Hondata intake manifold gasket, street setup
Hondata S200
toda cam gears +5, +5
Prelude '97+ 290cc/min injectors
Mugen thermoswitch
Mugen Intake
Old Mar 21, 2004 | 01:18 PM
calgary_redneck's Avatar
Default Re: (zad5)
Well make alot more noise and cost alot more money but won't give you any more power
Old Mar 21, 2004 | 04:05 PM
zad5's Avatar
mugen and comptech icebox don't make noise it will give you some horespower. but im not sure if you can dyno an intake correctly.
Old Mar 21, 2004 | 08:39 PM
nostreble's Avatar
Default Re: Stock intake box vs Aftermarket intake (cold/short ram)?? (mrtrex)
aftermarket would be better
Old Mar 21, 2004 | 10:52 PM
Biomechanic's Avatar
Default Re: Stock intake box vs Aftermarket intake (nostreble)
check out this:
http://www.ultramax.com.sg/Dyno.htm
Test #3
K&N filter Vs Taiwan made cotten filter.
As you know Taiwan made filter is OBX, Ractive, e.t.c.
Test #5
Honda Civic EK3 (M) with PIPERCROSS VS K&N
Pipercross give more torque. As you know torque is more important than HP.
& test #8
Honda Civic SIR (A) with CAI & Pipercross
boarderfatty
Jul 27, 2010 02:38 PM
rZm
Apr 1, 2007 04:52 AM
Amused
Aug 14, 2006 09:53 PM
Ill
Jun 25, 2004 04:36 PM
RPM
Oct 3, 2001 04:00 PM
