HELP HELP camberkit install
Old Mar 21, 2004 | 07:14 AM
sohc00's Avatar
Default HELP HELP camberkit install
HI guy i need some help. i just installed camber kit on my civic. i got no probem on driver side,but on the passenger side one of the bolt dit not come off ( the one that hold the ball jont.NOT 2 bolt that bolt to the fram( i mean the body) i tried very thing. tap it,spry it with liquid wrench,heat torque. i still coud' not get that sucker out. i jut wonder when u lose the bolt on passerger side u lose the bolt the other way form driver side i mean instead turn the bolt otherclockwise u turn it clockwise. it may sound stupid right,but is it possible? because when i turn the bolt otherclockwise on the passenger side it pull down lower contro arm but i support with the jack stand. when i lose the bolt on the driver side it pull lower contro up and the bolt come off easy .i want to try it but if i wrong that mean i tie the bolt instead lossing the bolt. i don't know if this make sense to u guy. i nedd some help i be appreciate u help and your time 4 read all this long stupid qustion.
Old Mar 21, 2004 | 01:04 PM
sohc00's Avatar
Default Re: HELP HELP camberkit install (sohc00)
THANKS A LOT FOR YOUR HELP
Old Mar 21, 2004 | 02:20 PM
97Alex's Avatar
So your talking about the crown nut (the nut with the cotter pin) is stuck?
Old Mar 22, 2004 | 01:36 AM
sohc00's Avatar
Default Re: HELP HELP camberkit install (97Alex)
i forgot to tell ya it is rear not the front side. there is no pin just a bolt i belive it call privoit bolt some like that .i'm not sure .i mean the one that bolt to ball jont(uca)
Old Mar 22, 2004 | 05:15 AM
Crazydave's Avatar
Impact Gun
ADeKK
Aug 7, 2010 04:10 PM
rhennin
Suspension & Brakes
12
Apr 12, 2007 12:16 PM
aznryd3r
Apr 25, 2006 08:21 PM
hellas
Jan 21, 2003 12:33 PM
Batoutahell
Oct 15, 2002 04:33 AM
