Suspenion problem?
Old Mar 20, 2004 | 08:31 PM
CTR-CRX's Avatar
Default Suspenion problem?
I have a question? My front passager suspenion is 1 inch higher then my driver side. Both side have the same thing in each side so why would one side site higher then the other. Anything u people know would help thanks?
Old Mar 20, 2004 | 10:22 PM
travis's Avatar
Default Re: Suspenion problem? (CTR-CRX)
What type of suspension? Is the spring seated completely on both sides? What are you using to measure this height difference? Are the springs the same length when you remove the load?
Old Mar 21, 2004 | 12:05 AM
CTR-CRX's Avatar
I have stock struts and and lowering spring. The spring is seated all the way down. It is really noticable height wise. I measure from the lip of my rim to the fender and it was 1 inch diffence? Why i dont know? please help.
Old Mar 21, 2004 | 01:10 AM
travis's Avatar
Default Re: (CTR-CRX)
So when you take the load off of the springs, are they the same length?
Old Mar 21, 2004 | 08:04 AM
CTR-CRX's Avatar
yes
bad-monkey
Suspension & Brakes
Feb 17, 2016 07:06 AM
i-VTEC_do_you
Suspension & Brakes
Mar 13, 2011 05:31 AM
Dubs13
Suspension & Brakes
11
Jun 2, 2009 05:55 AM
harmonator84
Mar 10, 2007 08:44 PM
a12rnulfo
Suspension & Brakes
Apr 19, 2006 02:17 PM
