B16 turbo what kind of numbers should I expect? Please post
Set up is:
JDM B16 1st Gen b16 fully rebuilt with CP 9:1 compression
Eagle rods
Stock sleeves
stock head just manley valves
rev hard turbo kit
hondata stage 2 w/ boost
rc 440 injectors
jdm pr3
14-18lbs
I would love to hear your opinions what I should do next. Who should I have tune? What boost do u think should be at? How much hp and torque should I be expecting? Please help!!!
Eagle rods
Stock sleeves
rev hard turbo kit
rc 440 injectors
jdm pr3
14-18lbs
i gotta 92 cx with b16a2 00si with t62-1/t3turbine, delphi 440cc injectors, aem fuel rail, cam gears, B&m regulator, and vortech, walbro pump, vafc, tial bov, wastegate, drag mani...and tuned at 226 hp w/ 160 torque...it feels good...i dunno how much more i should be getting but thats at 7 psi
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK2NR »</TD></TR><TR><TD CLASS="quote">in my eyes 18 pounds is way to much for stock sleeves </TD></TR></TABLE>
really? because i don't think the boost matters, its the power/cylinder pressures you have to worry about. The thing that all you are missing is that the only thing limiting his power potential is his injectors which will max @ ~300whp. The stock sleeves can hold 500whp rather easily. especially with the ideal r/s ratio of the b16a.
I personally made 310whp, stock b16a @14psi
B16a2
je piston, crower rods
fierra valve springs/ret.
8:8 comp.
440 cc inj.
t3/t4 60-1
stage 3 hondata w/B
15 psi (stock map sensor)
275 whp 195 tor.
Its all about the tuning baby! I don't care what you have i bet a b16 block (with proper tuning) could hold around 400-500 hp. <--- any thoughts?
8:8 comp.
440 cc inj.
t3/t4 60-1
stage 3 hondata w/B
275 whp 195 tor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ntrpriz »</TD></TR><TR><TD CLASS="quote">B16a2
8:8 comp.
440 cc inj.
t3/t4 60-1
stage 3 hondata w/B
275 whp 195 tor.
a built b16 could probably hold 400-500 no problem, but not a stock one....I put down 306whp/215wtrq @ 12 lbs on a stock JDM b16a motor and I am soon to be in the process of getting my other JDM b16a block built, but that won't be for a few months.....
8:8 comp.
440 cc inj.
t3/t4 60-1
stage 3 hondata w/B
275 whp 195 tor.
</TD></TR></TABLE>a built b16 could probably hold 400-500 no problem, but not a stock one....I put down 306whp/215wtrq @ 12 lbs on a stock JDM b16a motor and I am soon to be in the process of getting my other JDM b16a block built, but that won't be for a few months.....
We typically make ~325-330 whp on stock B16's with C16 at about 14-15 psi. If you run pump with about 10 psi or so, expect to make around 270ish.
Stock sleeves are good to a hell of a lot more than 18 psi. Our 'teg (B16 block w/ pistons and rods) was making 520 whp 390 tq on stock sleeves until a wrist pin went bye-bye.
Brian
Brian
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Firedrake »</TD></TR><TR><TD CLASS="quote">We typically make ~325-330 whp on stock B16's with C16 at about 14-15 psi. If you run pump with about 10 psi or so, expect to make around 270ish.
Stock sleeves are good to a hell of a lot more than 18 psi. Our 'teg was making 520 whp 390 tq on stock sleeves until a wrist pin went bye-bye.
Brian</TD></TR></TABLE>
my 306 is on 93 octane...i'd like to turn it up but don't want to run c16 since dis is my daily driver
your set up is pretty decent, a common rule of thumb is 10 horse for every pound of boost, BUT thats if you have have proper management IE: after market fuel pump, ignition ect. Stock honda cranks are forged and can hold up to 500 horse so you should be all set with a rebuilt b16 and a factory turbo kit built for it. My guess would be somewhere around 310 horse
good luck!
good luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bulldogg83 »</TD></TR><TR><TD CLASS="quote">
my 306 is on 93 octane...i'd like to turn it up but don't want to run c16 since dis is my daily driver</TD></TR></TABLE>
We typically tune the cars (stock B series) for C16 on 15 psi (so customers can run them on good gas at the strip) and then turn it down to 10 or so for pump gas (91 is the best we get around here
Brian
).....Brian
gotcha...what are they making around 10?
).....Brian</TD></TR></TABLE>
gotcha...what are they making around 10?</TD></TR></TABLE>
Like I said above, typically around 270 on 91 pump, but it'll vary between 250-275 depending on the setup and how good the components are, size of exhaust, good intercooler, etc.....
One guys hatch went 13.3 @ 109 on 10psi and pump (B18C1), full weight and drag radials......
Brian
Brian
I just weighed my car tonight and with me in it, the car is 2840, but I also had an extra set of headers, spare, and some other chit in there that I could have taken out....car is more likely around 2800 with me in it.......oh yeah and I have a full tank....
I'm not sure what turbo comes with the revhard kit, but turbo and injectors are gonna be the things needing upgrading for 400-500 whp. If you don't already have a 3 inch exhaust, get one, and think about having a 3 inch DP made as well.....
Like I said, we know for a fact stock sleeves in B16's are good for 500+ with good rods and pistons, it's just a matter of fuel and boost to get there (as long as you don't break a wrist pin that is
Brian
)Brian
