CAR won't start..please help
Old Mar 20, 2004 | 03:56 PM
veeDUB's Avatar
Default CAR won't start..please help
its a stock 96dx motor..
doesn't crank
no starter signal
checked all the fuses-- all good
all the grounding wires-- check
its not the battery-- radio works, headlights turn on
no clicking
what could it be??
any help will be appreciated...thanks
Old Mar 20, 2004 | 04:01 PM
blackhatchy's Avatar
Default Re: CAR won't start..please help (vtec 5 6 2)
the battery could be too weak to crank it. try jumping it.
Old Mar 20, 2004 | 04:46 PM
watacivic's Avatar
Default Re: CAR won't start..please help (blackhatchy)
check your main relay
Old Mar 20, 2004 | 05:27 PM
mantic6t9's Avatar
Default Re: CAR won't start..please help (watacivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by watacivic &raquo;</TD></TR><TR><TD CLASS="quote">check your main relay</TD></TR></TABLE>
When my main relay went bad the enging would crank but not turn over. He says the starter isn't even engaging. So i don't think that's the problems. It sounds like a dead battery which could be 'caused by leaving something on in the car over a period of time or a bad alternator not charging the system. Have you tried jumping the car yet?
If you don't think it's the battery your starter may have taken a dump on you.
Old Mar 22, 2004 | 09:37 AM
stickyfingers's Avatar
IGNITION COIL check that same thing happened to me
barnchips
Jul 19, 2013 11:34 AM
95-del-sol
Jul 15, 2013 08:12 PM
crxpwr1
18
Jun 30, 2007 09:03 AM
FindingEmo
Aug 5, 2004 06:46 AM
tan2
Nov 4, 2002 10:10 AM
