90-93 int. shaft won't fit in jdm b16
Old Mar 20, 2004 | 02:06 PM
crx_ef8's Avatar
Default 90-93 int. shaft won't fit in jdm b16
pics explain everything.
can i cut those part out? or shave the part on the engine?
Old Mar 20, 2004 | 02:20 PM
Discosteak's Avatar
Default Re: 90-93 int. shaft won't fit in jdm b16 (crx_ef8)
dremel tool is your best friend
Old Mar 20, 2004 | 02:25 PM
RTE117's Avatar
The 90-93 Tegs are different, well the axles are. I remember you only use the axles for H22's in Civics. Hmm, intermediate shaft is different too, learned something new today.
Old Mar 20, 2004 | 02:34 PM
crx_ef8's Avatar
Default Re: 90-93 int. shaft won't fit in jdm b16 (IDriveAHonda)
so is it ok to cut it?
Old Mar 20, 2004 | 03:08 PM
crx_ef8's Avatar
still doesnt fit, the hole not lining up right. can i use the 96 gsr shaft with 90-93 axles?
Old Mar 20, 2004 | 03:45 PM
Discosteak's Avatar
no the intermediated shaft is different wont work with the axles. get gsr axles
edit:for some reason now when i thimk about it im not so sure so dont listen to anything i just said
Old Mar 20, 2004 | 05:16 PM
crx_ef8's Avatar
Default Re: 90-93 int. shaft won't fit in jdm b16 (BADEG6)
so if i use 96 int. shaft i need to get 96 axles? but will this wrok on crX? i thought 90-93 only work?
Old Mar 20, 2004 | 06:43 PM
paybac4223's Avatar
Just call steve @ HMO on monday and see if he will swap you for the right ones...
http://www.hmotorsonline.com
Kusai.Nihonjin.Desu
13
Jun 23, 2009 05:45 PM
s2k_al
Apr 5, 2005 07:30 PM
RuthlessEF-9
11
Dec 9, 2004 01:23 AM
crxk20
Nov 13, 2002 04:18 AM
XANDER-666
Oct 7, 2002 12:04 PM
