another busted exedy organic clutch
Old Mar 20, 2004 | 01:34 PM
Rob Dizzle's Avatar
Default another busted exedy organic clutch
I took out my tranny today and found this:
So I am probaly going to get an oem clutch. im tired of dealing with stupid **** that keeps breaking.
i never went to the drag strip. hardly ever dropped the clutched or did agressive launches
my next car is going to stay stock
edit:
there are 2 of those parts where its cracked/broken
the other 2 parts are where you can see its been worn against when the spring moves
Modified by Bob-DC2 at 4:59 PM 3/20/2004
Modified by Bob-DC2 at 9:55 AM 4/7/2004
Modified by Bob-DC2 at 9:56 AM 4/7/2004
Old Mar 20, 2004 | 01:39 PM
96 Ls lnTeG's Avatar
Default Re: another busted exedy organic clutch (Bob-DC2)
How many Miles were on it???
Old Mar 20, 2004 | 01:44 PM
Rob Dizzle's Avatar
Default Re: another busted exedy organic clutch (96 Ls lnTeG)
maybe 25k
i drive alot of freeway miles though
go to tahoe and commute to school alot
havent even seen a track day yet with that clutch
does a b20 clutch work ?
Old Mar 20, 2004 | 02:10 PM
94gsr4dr's Avatar
exedy is crap, i had one, and it sucked
Old Mar 20, 2004 | 02:11 PM
Chiovnidca's Avatar
What was it doing? (Or not doing) I've seen alot worse.
Old Mar 20, 2004 | 02:20 PM
Rob Dizzle's Avatar
Default Re: another busted exedy organic clutch (Chiovnidca)
im swapping new engines in, and i had to take the clutch assembly off the old block
Old Mar 20, 2004 | 02:29 PM
Xumarius's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob-DC2 &raquo;</TD></TR><TR><TD CLASS="quote">
I heard of someone else here having same issues. I saw it like a long time ago though. But damn, no track days and it looks like that?
Old Mar 20, 2004 | 02:42 PM
J337_UNIT's Avatar
Default Re: another busted exedy organic clutch (Xumarius)
damn i have had my exedy for about 10k miles.. not one problem..and it handled a 50 shot really nicely.. lets see how it holds 9 psi of boost ..muhahahahahHAHA!
Old Mar 20, 2004 | 02:44 PM
B2FiNiTY's Avatar
Go with clutch masters or ACT.
If you want to get something for sure then go Toda or OEM/Spoon.
Old Mar 20, 2004 | 03:08 PM
Honda Hick's Avatar
How did you know there was something messed up with the clutch? Could you feel that little bit of breakage on there? That's a really weird spot to mess up. Looking at your disk, it looks like you didn't beat on it either. I'd just go OEM clutch now
Old Mar 20, 2004 | 03:16 PM
mikestypeR
Guest
Posts: n/a
I am glad you posted this .... i had the same clutch in my car and i blew out this past week taking most of the tranny with it now i am looking at a 1200 dollar rebuild and I give excedy a
I will never give them another dollar they suck big ****.
Old Mar 20, 2004 | 03:57 PM
Rob Dizzle's Avatar
Default Re: another busted exedy organic clutch (mikestypeR)
im putting a b20 motor into my car
and taking my gsr motor out
i couldnt tell that this was broken at all.
you can tell there is still alot of meat on it too
i wonder if its cause i slip teh clutch too much sometimes or what it could be from...
Old Apr 3, 2004 | 05:23 AM
highcomp's Avatar
the only thing I can see causing this is eather crazzy launch or down shifting into second gear when coming off the highway @like 50mph. Someting is definitly wrong with that particular clutch. And Im not a biest but exedy dose make all of honda/acura oem cluthes. Do a search youll find it or call a honda dealership with a good tech hell tell yah.
Old Apr 3, 2004 | 06:09 AM
Mattyg2's Avatar
damn and i was looking into getting an exedy clutch with act flywheel, wondering if i should still go with the exedy or not :-(
Old Apr 3, 2004 | 08:02 AM
au-gsr's Avatar
Default Re: another busted exedy organic clutch (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Go with clutch masters or ACT.
If you want to get something for sure then go Toda or OEM/Spoon. </TD></TR></TABLE>
hmm
well oem is made by exedy, spoon uses an exedy clutch disk but use their material on it and toda, well, not unless you want to sell your first born.
The cracking happens ewhen the person who installs the clutch doesn't follow the proper procedure for torquing down the pressure plate. We see it all the time at the dealership with the do it yourselfers' cars.
next time get a helms manual.
i have had an exedy race organic in the car for over two years, and i've pulled and replaced my tranny twice, no problems yet.
exedy is the only manufacturer to use all new, not refurbished clutch materials and equipment
ACT and Clutchmasters use recycled clutch disks. If it were me i would never install anything but an exedy clutch disk in my car.
other items you'll want to inspect are your slave and master cylinders. no fluid in them equals greater pushing force to get clutch to engage, which also, can rexult inthe cracking that happened to your clutch disk.
Also never buy a clutch pack off ebay, unless it is from a notable source you don't know what your getting. trust me there are tons of fake exedy clutches out there and exedy's website even goes over them.
the informed consumer is the best consumer.
Old Apr 3, 2004 | 08:38 AM
ru2slo's Avatar
cant see.. damn 56k .. where are all the good posts when im at work? nothing but Em0ne posting ugly cars..& pointless threads.
ouch. sorry man.
Old Apr 3, 2004 | 09:25 AM
Undercover_Skank's Avatar
exedy sucks....my friend we through 4 of those organic clutches....
Old Apr 3, 2004 | 09:29 AM
bkblazen2003's Avatar
yeah . you got to bolt it to torque specs. and in the right order
Old Apr 3, 2004 | 11:22 AM
Charlie Moua's Avatar
Ok you should give us some more facts about your setup so we know if exedy is crap or not. 25,000 miles on a clutch is decent. You also have to ask yourself if you installed it correctly.
I've seen exedy clutches up close after 10-15-20k of useage and they have all held up fine for street racing and daily driving.
Did you get the RACE or the OEM replacement?
What mods do you have?
The Race organic can tyipically hold roughtly 200-225lb tq
the OEM is right around 165lbs tq
Old Apr 3, 2004 | 02:33 PM
CaptinMcnut's Avatar
mine help pretty well at 18psi but the engine on the other hand did not
Old Apr 3, 2004 | 02:48 PM
B*A*M's Avatar
Default Re: another busted exedy organic clutch (Charlie Moua)
i have the organic race clutch with roughly 25k miles. it's still running strong.
Old Apr 3, 2004 | 03:14 PM
xplanetearth420x's Avatar
that **** is f*cked up
Old Apr 3, 2004 | 04:14 PM
rated_r's Avatar
Default Re: another busted exedy organic clutch (xplanetearth420x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xplanetearth420x &raquo;</TD></TR><TR><TD CLASS="quote">that **** is f*cked up</TD></TR></TABLE>
yup
Old Apr 3, 2004 | 04:17 PM
FlaN.'s Avatar
Default Re: another busted exedy organic clutch (Vietvicious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vietvicious &raquo;</TD></TR><TR><TD CLASS="quote">exedy sucks....my friend we through 4 of those organic clutches....</TD></TR></TABLE>
you'd think he'd realize after maybe, 2.
Old Apr 3, 2004 | 09:55 PM
ACTman's Avatar
Default Re: another busted exedy organic clutch (au-gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by au-gsr &raquo;</TD></TR><TR><TD CLASS="quote">well oem is made by exedy...</TD></TR></TABLE>Sorry but Exedy is not OE on B-series Honda, FCC is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by au-gsr &raquo;</TD></TR><TR><TD CLASS="quote">The cracking happens ewhen the person who installs the clutch doesn't follow the proper procedure for torquing down the pressure plate. We see it all the time at the dealership with the do it yourselfers' cars....next time get a helms manual.</TD></TR></TABLE>Sorry, torque of the clutch bolts has nothing to do with this type of premature wear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by au-gsr &raquo;</TD></TR><TR><TD CLASS="quote">...exedy is the only manufacturer to use all new, not refurbished clutch materials and equipment...ACT and Clutchmasters use recycled clutch disks.</TD></TR></TABLE>ACT uses refurbished clutch materials...recycled?? Now your ignorance is really showing. Come on over and I will give you a tour, dude.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by au-gsr &raquo;</TD></TR><TR><TD CLASS="quote">...i have had an exedy race organic in the car for over two years, and i've pulled and replaced my tranny twice, no problems yet. ...If it were me i would never install anything but an exedy clutch disk in my car.</TD></TR></TABLE>This may suprise some folks, but I think Exedy is good stuff as well.
This type of premature wear (as shown in the pics) is almost always caused by torsional vibration. There are numerous causes or contributors, such as cam changed, high boost, lightened flywheel, aftermarket front dampener, high compression, etc. Basically, if it improves power or acceleration, it increases torsional vibration. Any increase in torsional vibration will play havoc on the disc center that is trying to dampen out the vibration, thus wearing the disc center prematurely. I don't think Exedy can be blamed for the wear. I think if we do down the list of parts in the car's setup, we could find some mods that are contributing to the wear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by au-gsr &raquo;</TD></TR><TR><TD CLASS="quote">...the informed consumer is the best consumer.
</TD></TR></TABLE>Amen... but please make sure it's the right information.
