Air Flow Sensor
Old Mar 20, 2004 | 01:20 PM
djwest24's Avatar
Default Air Flow Sensor
k...quick question, i was wiring up my SAFC...and i dont know if my DX has the hot-wire/flap/pressure type sensor or the karmann freq sensor?
i thought it was the pressure type...just need to confirm....thanks
Old Mar 20, 2004 | 02:11 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Air Flow Sensor (quicksilver17981)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver17981 &raquo;</TD></TR><TR><TD CLASS="quote">k...quick question, i was wiring up my SAFC...and i dont know if my DX has the hot-wire/flap/pressure type sensor or the karmann freq sensor?
i thought it was the pressure type...just need to confirm....thanks</TD></TR></TABLE>
Sounds like you're describing a MAF or Mass Air Flow system, which is how some cars measure how much air is coming into the engine (some Toyotas, Mazdas, DSM's, pretty much every OEM turbo car). Most Hondas (if not all of them) use a MAP system, or Manifold Absolute Pressure. It uses a sensor that measures the amount of vacuum in the intake manifold and from that figures out how much air is coming into the engine. The problem with the Honda MAP sensors is that they cannot read positive pressure (or boost) and tend to freak out if a turbo is installed.
Old Mar 20, 2004 | 02:28 PM
RTE117's Avatar
Default Re: Air Flow Sensor (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
The problem with the Honda MAP sensors is that they cannot read positive pressure (or boost) and tend to freak out if a turbo is installed.</TD></TR></TABLE>
w0rd. GM 3 bar MAP's own.
Old Mar 20, 2004 | 03:20 PM
djwest24's Avatar
Default Re: Air Flow Sensor (IDriveAHonda)
yea...i need to get myself one of those...for now im just gonna run 6lbs, till i build the block...so stick with the stocker. thanks guys...
Old Mar 20, 2004 | 05:00 PM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver17981 &raquo;</TD></TR><TR><TD CLASS="quote">yea...i need to get myself one of those...for now im just gonna run 6lbs, till i build the block...so stick with the stocker. thanks guys...</TD></TR></TABLE>
I'm pretty sure the ECU will throw a code if the MAP sensor detects ANY boost. I'm not sure though.
Old Mar 21, 2004 | 09:24 AM
djwest24's Avatar
from what i heard, if the boost is under 10lbs it shouldnt throw a CEL.
1988crxdx
Jun 3, 2009 02:56 PM
iwantspeed
Honda Civic (2001 - 2005)
11
Jan 5, 2007 07:20 PM
Layziebtnh055
Apr 14, 2004 07:58 AM
freeplay
Nov 16, 2002 05:42 AM
SilverIntegra
Apr 16, 2002 11:32 AM
