200lbs compression on a DOHC ZC
Old Mar 20, 2004 | 01:20 PM
pyro_freak8's Avatar
Default 200lbs compression on a DOHC ZC
i just got a DOHC ZC and did a compression test using an Actron tester...
i got a reading of 200-200-200-200. i did a search and see that alot of people are getting around 140-180... does it sound like maybe my gauge is bad or is the engine just in really good shape. it's supposed to have around 40,000 miles and this tester is brand new. thanks for any input....
Old Mar 20, 2004 | 01:29 PM
96-EJ6 B18C's Avatar
Default Re: 200lbs compression on a DOHC ZC (pyro_freak8)
Sounds like you got a very strong motor!
Old Mar 20, 2004 | 01:33 PM
Project91CRX's Avatar
Use that gauge and test it on another motor to see if it's messed up or not.
Old Mar 20, 2004 | 01:37 PM
iain's Avatar
Default Re: (Project91CRX)
lmy last compression test yielded
1: 208
2: 205
3: 190
4: 195
so i'd say you're fine
Old Mar 20, 2004 | 02:05 PM
i tested on a d16 i knew was shot and it said 35-120-100-130..... it's definitely a shot engine so the test didn;t surprise me.. cylinder 1 it spewing oil and i knew it'd be horribly low
MREG2
Apr 26, 2008 06:59 PM
MRN1120
Jul 9, 2006 02:17 PM
civhatch90
May 8, 2005 02:09 PM
yoshi234
Feb 19, 2003 12:45 PM
