90-93 engines
Old Mar 20, 2004 | 12:33 PM
cyberneo344ib's Avatar
Default 90-93 engines
I was wondering what was the difference between an f22a1 engine and a f22a6 engine. I looked at the compression ratio's and they look the same. Is the difference the intake manifold?
Old Mar 20, 2004 | 12:46 PM
FatJoe's Avatar
Default Re: 90-93 engines (cyberneo344ib)
intake manifold and exhaust manifold and downpipe...exhaust manifold is a 4-2-1 for the a6 a1 is a 4-1...intake manifold has a butterfly valve which helps create more power for ther a6...a1 doesnt have it...there you go
Old Mar 20, 2004 | 02:17 PM
Default Re: 90-93 engines (FatJoe)
Thank you. Do you know of any difficulties swapping the intake and exhaust to the a1?
Old Mar 20, 2004 | 02:27 PM
The_Todd's Avatar
Farts in the shower
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cyberneo344ib &raquo;</TD></TR><TR><TD CLASS="quote">Thank you. Do you know of any difficulties swapping the intake and exhaust to the a1?</TD></TR></TABLE>
None that I can think of.....should just bolt right up, and some people like to swap ECU's too. Basically your converting lx to ex its one basically a expensive way to get a few hp unless you plan on boosting .
Old Mar 20, 2004 | 06:55 PM
ACCORDianate's Avatar
The cam is different too. Might be cheaper to just buy a head off a wrecked Accord and plop it on instead of buying a new cam.
Old Mar 21, 2004 | 05:57 AM
miedosoracing's Avatar
Default Re: (ACCORDianate)
sorry to jack your post, but then the heads are the same? I was wondering if the cams are different, or they can be switched. Thanks
Old Mar 21, 2004 | 08:48 AM
F22A1 - LX, DX
125hp
F22A4 - EX (90-91)
130hp - difference is a 4-2-1 exhaust manifold, and slightly larger diameter exhuast
piping
F22A6 - EX (92-93), SE
140hp - difference is a diff. computer, 4-2-1 exhaust manifold, different camshaft, and
a dual stage intake manifold (all are direct swaps).
If you're in the Dallas area, you could pull all the stuff you need from a few wrecked Accord at Honda Heaven in Arlington. http://www.h-heaven.com
Old Mar 21, 2004 | 08:50 AM
Do you know how much of a hp difference the cam makes from the a1 to the a6?
Superdragr45
Oct 18, 2019 04:35 AM
turbolshatch
Welding / Fabrication
Oct 30, 2007 03:31 PM
hondacrx2
May 23, 2007 08:28 AM
abmerop18
Apr 13, 2006 12:14 PM
