carsound cat...only 1 o2 sensor?
Old Mar 20, 2004 | 08:33 AM
blackacteg96's Avatar
Default carsound cat...only 1 o2 sensor?
aight guys...i just got in a direct bolt-in carsoud cat for my 96 gsr....my original cat has 2 holes for the o2 sensors...but the carsound only has 1 hole after the cat...was i shipped the wrong one? or am i just supposed to hook up the primary o2 sensor in the hold...and disconnect the secondary? thanks guys...n btw...i did search...n the fact that i didn't find anything about this makes me lean toward carsound sending me the wrong cat
Old Mar 20, 2004 | 09:12 AM
Rory Breaker's Avatar
Default Re: carsound cat...only 1 o2 sensor? (blackacteg96)
Who did you order it from?
You should have 2 bungs in your cat for a 96 GSR.
Old Mar 20, 2004 | 09:53 AM
i ordered it from nopi.com...but carsound drop shipped it...i guess i'll have to send it back..thanks for ur help newgsrdriver...n btw..luv da pic...GO SKINS!!!
Old Mar 20, 2004 | 10:03 AM
Default Re: (blackacteg96)
You know it man....I need to switch it up a bit and get my man CP on there
BTW - definitely dont pay to ship it back, that should all be their cost, since they are the ones who fucked up. Get them to compensate you, they should know better.
Old Mar 20, 2004 | 10:07 AM
aight man...definately...i'm not payin anything more than the original cost to get it...i just wasn't sure if it was possible to just bypass the secondary o2 sensor and only have the primary after the cat...trick the ecu into runnin harder...but i guess not..thanks for da help man
Old Mar 20, 2004 | 03:58 PM
Audio28's Avatar
actually, you can have a new o2 bung welded on the carsound cat. mine didn't have any, and I went to the muffler shop and welded both onto the carsound cat.
Old Mar 22, 2004 | 10:18 AM
oh...really audio28? how much did they charge you? i'm takin my car to da track on sat...i know it won't make that big a diff...but it'd be nice to have it on before i run....
rjmq06
Sep 12, 2010 03:05 PM
92eghb
12
Feb 27, 2009 08:32 AM
joshcivic00
Nov 11, 2005 10:49 PM
Toda Party
Dec 26, 2001 11:47 AM
