help i ran a 16.7
Old Mar 20, 2004 | 06:34 AM
Exclusiv3's Avatar
Default help i ran a 16.7
I have an '97 stock LS and i ran 16.7. Should i go auto-X or should i go with a drag setup?What will be the funest setup for theleast amount of money?
By the way, what are the shift points and launch point on an LS? I tryed almost everthing and the lowest time was 16.7.
Old Mar 20, 2004 | 06:41 AM
LSTEG96's Avatar
Default Re: help i ran a 16.7 (Exclusiv3)
u really suck at driving, stop beating on that poor car
Old Mar 20, 2004 | 06:42 AM
cu_jarrett's Avatar
I ran a 15.4 with 7000 rpm shifts, and 4500 luanch in my LS. What you do is all up to you. Try them both.
Old Mar 20, 2004 | 06:43 AM
JDMThoughts's Avatar
From: Standing on the corner selling cocaine, rippin shows live on stage for hoes yellin my name
That sounds a rough man. My friend ran a 15.7 with only an AEM cold air intake installed. Was your clutch slipping? Is your motor sound; you should give it a tune-up and check the compression. How about your tires? There are a lot of things that could make up for your slow time. How long have you been driving? I know a few people who are just new to driving a standard mission, and have slower times, but if your car is stock and in good health, it can only be left up to driver skill. I don't wanna say you aren't good at driving, but driver skill is really important. You don't have any giant blinger wheels or monster bodykits do you? Perhaps a really heavy audio install? Reply back with some more info.
Old Mar 20, 2004 | 06:44 AM
stasi's Avatar
Default Re: help i ran a 16.7 (LSTEG96)
I'd say keep it stock for now and don't waste your money.
16.7? iu'm not sure if it was your driving or your car was
running like crap. Was that your first time on the strip?
Old Mar 20, 2004 | 06:50 AM
Exclusiv3's Avatar
Default Re: help i ran a 16.7 (stasi)
it was my first time at the strip but i have been driving standard tannies for a will just not an integra. So could you guy give me some tips on shifting and launching
thanks for your help
Old Mar 20, 2004 | 06:53 AM
Exclusiv3's Avatar
Default Re: help i ran a 16.7 (cu_jarrett)
by the way it was fully loaded with full leather interior (if that makes a difference)
Old Mar 20, 2004 | 07:08 AM
Do a tune-up and check the compression. How does the clutch feel? If you have been driving standard missions for a while then I will rule out driver not having skill, it might be in the car, it might not be you at all.
Old Mar 20, 2004 | 07:21 AM
Exclusiv3's Avatar
Default Re: help i ran a 16.7 (JDMThoughts)
oh, my other question. Is it a wast of money doing a drag setup b/c i have heard integras are great auto-X cars?
Old Mar 20, 2004 | 07:22 AM
ArizSun21's Avatar
From: Do I look like Michael Bolton from Office Space,, MD, USA
Don't give up if you ran a slow first time!!! You just need practice
I have never done auto-cross but I would assume it would be more exciting then drag racing.
Try to shift at red-line or experiment to see which shift point works for you. I launch at around 3.5-4.5k.
Old Mar 20, 2004 | 07:23 AM
Exclusiv3's Avatar
I just bought the car from carmax and the clutch feels alright exept the friction point is alittle too small (that would be better for drag racing anyways
Old Mar 20, 2004 | 07:33 AM
t . b o z's Avatar
well, with hondas the clutch engages about half way through the pedal.(well all the ones I have driven)
Old Mar 20, 2004 | 10:48 AM
sa21199's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Exclusiv3 &raquo;</TD></TR><TR><TD CLASS="quote">I have an '97 stock LS and i ran 16.7. Should i go auto-X or should i go with a drag setup?What will be the funest setup for theleast amount of money?
By the way, what are the shift points and launch point on an LS? I tryed almost everthing and the lowest time was 16.7. </TD></TR></TABLE>
what is your 60ft time??
Old Mar 20, 2004 | 10:52 AM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Exclusiv3 &raquo;</TD></TR><TR><TD CLASS="quote">oh, my other question. Is it a wast of money doing a drag setup b/c i have heard integras are great auto-X cars?</TD></TR></TABLE>
Yes, Integra's are wonderful for autocrossing and road racing. A few suspension mods and lots of practise will have you chasing the corvettes in the tight corners.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sa21199 &raquo;</TD></TR><TR><TD CLASS="quote">what is your 60ft time??</TD></TR></TABLE>
Finally, the question we've all been waiting for.
Old Mar 20, 2004 | 11:35 AM
LSTEG96's Avatar
Default Re: (DA-teggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA-teggy &raquo;</TD></TR><TR><TD CLASS="quote">well, with hondas the clutch engages about half way through the pedal.(well all the ones I have driven)</TD></TR></TABLE>
its not because its a HONDA clutch...please... its simply because the driver hasnt done 300 burnouts and smoked the **** out of it
Old Mar 20, 2004 | 12:09 PM
FastSS's Avatar
Default Re: (LSTEG96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 &raquo;</TD></TR><TR><TD CLASS="quote">
its not because its a HONDA clutch...please... its simply because the driver hasnt done 300 burnouts and smoked the **** out of it </TD></TR></TABLE>
I take it you dont have much experiance with other cars...
Honda Clutches engage higher than most other clutches, this is a proven fact.
Mitsubishi catches very low, and when you install an aftermarket piece it engages lower.
I believe by changing the thickness of the Throw-Out bearing you could probably change the engagement point... that is just theory of course...
anyway, honda clutches engage mid way up at the earliest, if your clutch engages lower then you have thrown a spring retainer and it is trapped between your clutch disk and something else... ive also had this happen, its not good for any of the parts in your clutch.
as for the 16.7, dont let them fool you, that is a very respectable time for your first time out.. dont expect to hit much into 15s with an LS, if at all
Old Mar 20, 2004 | 07:31 PM
95VXB16A's Avatar
Muh, average time with your car and mods
Old Mar 20, 2004 | 07:53 PM
xdjoynerx's Avatar
i think a stock ls should be in the upper 15s............................................... .................................. and imo, hondas engage LOW. compared to other manuals ive driven.
Old Mar 20, 2004 | 08:02 PM
Sergei01's Avatar
Default Re: (xdjoynerx)
who cares if its 16.7, as long as you peel away from a civic with 18s and a body kit at a stop light at 1 am.
Old Mar 20, 2004 | 08:10 PM
MooreBoost's Avatar
Default Re: (Sergei01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sergei01 &raquo;</TD></TR><TR><TD CLASS="quote">who cares if its 16.7, as long as you peel away from a civic with 18s and a body kit at a stop light at 1 am.</TD></TR></TABLE>
Spoken like a true ricer.
Old Mar 20, 2004 | 08:16 PM
FastSS's Avatar
Default Re: (tegunderpressure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">
Spoken like a true ricer.</TD></TR></TABLE>
Agreed
Old Mar 20, 2004 | 09:09 PM
Sergei01's Avatar
who me? a ricer. i dont go look for people to race at night.
but whatever
Old Mar 20, 2004 | 09:17 PM
FastSS's Avatar
Oh Im sorry, were you not talking about peeling away from people at a stop light?
Old Mar 20, 2004 | 10:08 PM
adddddaaammmm's Avatar
Default Re: (FastSS)
16.7 isnt that bad dude... id practice alot more if you wanna go drag tho... i had my LS built with crower components and the basic bolt ons. i ran 15.2 on 16in volks with full interior. i started getting into auto X and i used tein re as my suspension with edfc. IMO auto X is way more fun.
Old Mar 21, 2004 | 08:51 AM
Exclusiv3's Avatar
Default Re: (00fbpitr54)
thanks for all your suport. One of my friends told me that at the friday night track event that they add you reaction time to your 1/4 mile time. Im like an old person i dont react very quick
