Need Secondary O2 Sensor Wiring Diagram.
Old Mar 20, 2004 | 04:57 AM
bo0sted's Avatar
Default Need Secondary O2 Sensor Wiring Diagram.
My Secondary O2 got unpluged when taking off my header causing the exhaust to drop and pulled out the pins on the Secondary sensor. Instead of guessing 16 times, because the pins got pulled out, I am asking you guys to help me out. If anybody has a diagram or if anybody can tell me what color from the o2 to what color on the harness, that would be great.
Old Mar 20, 2004 | 05:28 AM
bo0sted's Avatar
Default Re: Need Secondary O2 Sensor Wiring Diagram. (MwGSR)
Oh yah my car is a 2000 GSR.
Old Mar 20, 2004 | 01:52 PM
bo0sted's Avatar
Anyone?
Old Mar 20, 2004 | 02:11 PM
FastSS's Avatar
#1, it should be the same as the first one, and #2, the wire colors do match up between the two plugs... pull the split loom off the wire, hit it with some brake parts cleaner and a towel and figure it out, if you still need help ill try to find the diagram.
Old Mar 20, 2004 | 04:04 PM
bo0sted's Avatar
Default Re: Need Secondary O2 Sensor Wiring Diagram. (FastSS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FastSS &raquo;</TD></TR><TR><TD CLASS="quote">#1, it should be the same as the first one, and #2, the wire colors do match up between the two plugs... pull the split loom off the wire, hit it with some brake parts cleaner and a towel and figure it out, if you still need help ill try to find the diagram.</TD></TR></TABLE>
#1) Its not the same as the first one.
#2) The colors do not match up from the two plugs.
If it was that easy i wouldn't need a digram.
Old Mar 20, 2004 | 07:05 PM
FastSS's Avatar
I take it the wires are not the same due to the fact that you do not have the stock O2 sensor?
Old Mar 20, 2004 | 07:26 PM
FastSS's Avatar
And honestly if the wires arent the same color then you are fucked, unless of course you know what the new wire colors mean, and if you do then you already know how to put it back together, unless of course you know what they are but not where they go...
Hope this helps.
Old Mar 24, 2004 | 10:25 PM
bo0sted's Avatar
Still never figured this out.
Old Jan 24, 2005 | 06:36 PM
95tegNONVTEC's Avatar
good advice man...im gonna get off my @55 and go try that seein as how my o2 sensor has been unplugged for like a year now
primeredbeast
Aug 16, 2005 11:10 AM
IVI
Mar 27, 2004 04:47 AM
boostedcvc
Oct 13, 2003 11:46 AM
khang77642
May 15, 2002 01:06 PM
