92-96 vs. 97 radio installation....please help.
I installed 97 prelude cd player in a 95 lude and somehow only 3 rear speakers work, not the 2 front speakers. anyone knows why? also, does the 92-96 model come with stock cd player? if so, i might as welll get the old one.
humm, well i'm assuming you cut the plug off of your 95 harness because the 2 harnesses aren't the same, so i'd check and make sure you have all of the speaker colors right, and i think the 92-96's only had changers, i could be wrong though, just buy an aftermarket deck
There is no reason why that should happen the harness is the same for 4th gen and 5th gen I put a 97 cd player into a 92 and it worked perfectly no problem. Try putting the original cd player in and see if the same problem happens because there is no reason for that to happen.
pjr710
Audio / Security / Video
12
Jul 11, 2006 07:48 AM
turbochargeb18c
May 21, 2006 11:08 AM
