Which crossmember should i get?
i have a crx w/ a jdm 4-1 type r header and my crossmember broke. what crossmember should i get to replace my broken one? i was thinking of getting the jim fab, z10, stock, or possibly this one.
what crossmembers do you guys use? thanks
That crossmeber looks like a total rip of the jim fab... And I would recommend a jim fab because that is what I have and they work excellent. Jim also has great customer service.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 »</TD></TR><TR><TD CLASS="quote">get 'full race'.. not sure if they are out yet though..</TD></TR></TABLE>
i have a place racing... and im waiting on this ^ one to come out and i will buy it
the place racing one doenst really do anything for performance, it just allows for a 92-95 civic radiator and extra clearance
get the z10 man...or if your located in NY...nrg tech can make some custom traction bars for ya....im either getting the z10..or getting the custom ones...ill have pictures soon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CWESTINDC2 »</TD></TR><TR><TD CLASS="quote">will a jim fab clear a jdm 4-1 header tho? on the website it says it "may not"?</TD></TR></TABLE>
I have yet to see someone with a JDM 4 into 1 header post and confirm clearance. I would also like to see pictures. Right now Im running a JDM ITR engine with its own Hydro tranny ( HaSport cable to Hydro kit ).
I had to make cut, bend, and pound the heck out of the stock crossmember to clear the JDM header and the "skid plate" it comes with.
I had to cut the skid plate a little short in length to clear my CUSCO lower Tie bar.
It would be great to confirm if the JimFab clears the JDM header.
the full race strip bars for the ef will be released within the next month or so. the design is finished and the prototype is fabbed up, i will get some pictures of it as soon as possible.
also, the bars allow for plenty of room for any type of header, or downpipe while maintaining the rigidity needed to put your hp to the ground and keep it there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRex91 »</TD></TR><TR><TD CLASS="quote">Wait for Full Race
whats the advantages of the full race over the jim fab? ive read alot of good stuff about the JF...is the FR gonna be that much better...is it worth the wait... im also lookin for one just wondering?
</TD></TR></TABLE>whats the advantages of the full race over the jim fab? ive read alot of good stuff about the JF...is the FR gonna be that much better...is it worth the wait... im also lookin for one just wondering?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c jackson »</TD></TR><TR><TD CLASS="quote">
also, the bars allow for plenty of room for any type of header, or downpipe while maintaining the rigidity needed to put your hp to the ground and keep it there. </TD></TR></TABLE>
the full race strip bars for the ef will have heim joints at both ends of the radius rod, making it much much easier to adjust. if you look at the picture at the top of the thread, you have to take off the radius rod from either the lower control arm or the crossmember to adjust the rod. you wont have to do that with the full race xmember. just a simple twist of the locking nuts on each end, and turn the rod to whatever length you need, making it easy to pre-load the suspension.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c jackson »</TD></TR><TR><TD CLASS="quote">the full race strip bars for the ef will be released within the next month or so. the design is finished and the prototype is fabbed up, i will get some pictures of it as soon as possible.
i wouldnt mind seeing a pic of the prototype.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c jackson »</TD></TR><TR><TD CLASS="quote"> you wont have to do that with the full race xmember. just a simple twist of the locking nuts on each end, and turn the rod to whatever length you need, making it easy to pre-load the suspension. </TD></TR></TABLE>
Sounds great..but wont that throw your toe off? Requiring an alignment every time you play with them?
