condensation...how to fix it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">Seal it with some clear silicone. You can get some at Wal-Mart, or any auto parts store.</TD></TR></TABLE>
ok how do i get the water out thats in it now
let it dry out somewhere, or open it up. you could also try a hairdryer
*edit dont the turn signals have a hole in them to let them air dry when moisture builds up inside of them? see if the hole is plugged also
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theJUMPoff »</TD></TR><TR><TD CLASS="quote">let it dry out somewhere, or open it up. you could also try a hairdryer</TD></TR></TABLE>
i dont think u can open it up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theJUMPoff »</TD></TR><TR><TD CLASS="quote">yes you can. u put them in an oven and let it heat up til the seal gets gooey, then you pry it apart</TD></TR></TABLE>
thanx..how long
thanx..how long
Guest
Posts: n/a
I had the same problem with my headlights on my old gsr ... you need to get a hairdryer and stand there for a lonnnnnnnnggggggg while drying them out ... then go around all the seals were the plastic meets with silicon let them dry over night .... then they will be fine...
weakGOODJunKieS.com
Apr 13, 2003 11:07 AM
