Rattling steering wheel.....
Old Mar 19, 2004 | 07:52 PM
Beat2Shit's Avatar
Default Rattling steering wheel.....
When I drive my car, it has a constant rattle in the steering wheel that fades away, then it starts rattling again and fades out. It happens the whole time I drive it but it's the worst on the freeway. I don't have power steering, but I don't have power steering in my '73 f-250 either and it doesn't do that. As far as I know the steering and drivegear is fine.....Any ideas..??
Old Mar 19, 2004 | 07:54 PM
jwogen1's Avatar
Default Re: Rattling steering wheel..... (Beat2Shit)
do you think its the actual steering wheel or could you have some alignment or tires issues?
Old Mar 19, 2004 | 07:57 PM
Beat2Shit's Avatar
Default Re: Rattling steering wheel..... (jwogen1)
I totally doubt it's allignment....it may be tires, as the ones I have on it are mismatched, but it's too drawn out to be tires I think......
Old Mar 19, 2004 | 08:00 PM
jwogen1's Avatar
may just want to have it looked at, and see if it is a major issue or if you can fix it yourself
Old Mar 19, 2004 | 08:02 PM
Beat2Shit's Avatar
No $$$
Old Mar 19, 2004 | 08:37 PM
pimpinhonda's Avatar
have the alignment checked, and see if a belt is broken on the tires. also try and rotate your tires front to back and see if that helps. If it does it at 55mph or faster, have your tires balanced
Old Mar 19, 2004 | 10:02 PM
FatJoe's Avatar
Default Re: Rattling steering wheel..... (pimpinhonda)
mismatching tires makes one side track better than the other... could be quite dangerous under the right circumstances... not smart really...and it sounds like a balance problem...more than likely related with the tires.
Old Mar 21, 2004 | 05:23 AM
Beat2Shit's Avatar
Default Re: Rattling steering wheel..... (FatJoe)
Well, looks like alignment and tires are where I should start then. I'll keep ya posted. Thanks!
MinimusMaximus
Suspension & Brakes
10
Sep 11, 2015 11:28 AM
Jaynik
Nov 11, 2010 01:13 PM
JoKarma
Sep 20, 2005 10:56 AM
Toretto
Sep 15, 2004 10:58 AM
i_krayzie_i
Apr 6, 2002 08:04 AM
