CRX TO HATCHBACK SWAP ?????? MAP?
Old Mar 19, 2004 | 07:35 PM
crx si 2004's Avatar
Default CRX TO HATCHBACK SWAP ?????? MAP?
ok so i have an 88 crx si and i took the motor out and put it in the new 90 hatch only problem is the map sensors are different the plugs dont match up so i ended up using the one from the hatch ,, and it starts but it doesnt idle and shuts right off, if i hold in the gas it runs, but idles high and low like an idle air controll valve or something any suggestions
Old Mar 19, 2004 | 07:38 PM
dashpot solenoid valves??
Old Mar 20, 2004 | 01:04 AM
Fobtions's Avatar
Default Re: (crx si 2004)
sounds like
1. vacuum to the map is wrong
2. tps map iacv plugs are swapped in the wrong places
Old Mar 20, 2004 | 06:31 AM
does anyone have a vacume diagram for a 90 hatch si from the dashpot/ map to intake manifold??
DemonicRedneck
Feb 20, 2017 08:20 AM
Ef4doorwagon
Feb 12, 2014 09:25 AM
