GSR'S running CTR PISTONS?
Old Oct 21, 2001 | 08:02 AM
AllMotorMark's Avatar
Default GSR'S running CTR PISTONS?
My friend wants to put CTR's in his B18C1 and he has the race grind from crower (403's) do you think he will have valve to piston clearence problems?
Old Oct 21, 2001 | 08:05 AM
non-VTEC's Avatar
Default Re: GSR'S running CTR PISTONS? (T.O.STREETRACER)
probably not.............as long as he doesnt mill the cylinder head or use a thinner headgasket......
Old Oct 21, 2001 | 10:10 AM
Rhetoric's Avatar
My friend ran Ctr pistons w/ a ported Gsr head, itr cams/manifiold, 64mm tb, Pyr ecu and tuning. Everything put together by Pyr when they were in So. Cali. It dyno'd at 195.
Old Oct 21, 2001 | 11:02 AM
Tony the Tiger's Avatar
GSR head and CTR pistons = 12.7+ :1 CR!
Hey DontBother, why is he wasting his time? Why bother posting if you are not even giving any details? Might as well "don't bother"...lol
Old Oct 21, 2001 | 11:09 AM
Turbo00's Avatar
New User
Default Re: GSR'S running CTR PISTONS? (Tony the Tiger)
yeah my buddy LJ was running that set up also.
Old Oct 21, 2001 | 12:48 PM
Default Re: GSR'S running CTR PISTONS? (Turbo00)
sounds great, he has the skunk2 manifold and a 64mm throttlebody and a katman chipped p28, so it should run good!! Thanks for your help guys I'm new here and eveyone seems helpfull THANKS ALOT. I know alot about this stuff but numbers and experience are 2 differnent things. I'll take experience over numbers any day!!!!
Old Oct 21, 2001 | 02:39 PM
FAST94GSR's Avatar
New User
I've got CTR pistons in my engine. Compression is the best way to get more power. You need them if you're running big cams. I'm not a big fan of the Crower's but hey whatever floats your boat.
Old Oct 21, 2001 | 04:15 PM
immortal's Avatar
Banned
Default Re: GSR'S running CTR PISTONS? (DontBother)
don't bother cause you're a stupid ***.
go post else where..
Old Oct 21, 2001 | 04:29 PM
FSTASNTZ's Avatar
Clearance issues should be fine with stock valves. If he is going to larger valves, he may need to have the valve releifs in the pistons machined to fit...
Jason
Old Oct 21, 2001 | 04:48 PM
vtcntgragsr's Avatar
New User
Default Re: GSR'S running CTR PISTONS? (FSTASNTZ)
CTR pistons on a GSR are a real good idea, I'm about to shortly.
One thing:
CTR pistons+GSR head does not equal 12.7:1 CR, that's ridiculous. You'll be at 10.8:1 tops depending on whether you choose a thinner head gasket or not. A mugen head gasket will give you 11:1 CR. 12.7:1 isn't even streetable, unless you like spending $3 a gallon on 103 octane.
Old Oct 21, 2001 | 04:57 PM
Reid's Avatar
Global Moderator
Default Re: GSR'S running CTR PISTONS? (vtcntgragsr)
Please show the math you did to calculate this compression ratio. Recheck your figures, 10.8:1 is incorrect.
Old Oct 21, 2001 | 05:06 PM
Mike K's Avatar
Default Re: GSR'S running CTR PISTONS? (Reid)
Yea, I'd like to know your mathematical formula as well.
If your formula stands true, then a stock ITR's numbers for cc, piston dome, stroke, etc. should leave you with about 7.5:1.
LOL.
Old Oct 21, 2001 | 05:18 PM
FSTASNTZ's Avatar
It is not 12.7, close, but not there. I thought it was about 12.53:1. I know, 12.7 to 12.53 is like splitting hairs...
Either way, it is way more than 10.8:1...
Jason
Old Oct 21, 2001 | 05:25 PM
smerk's Avatar
New User
Default Re: GSR'S running CTR PISTONS? (Mike K)
hehe he may be in for a rude awakening if he puts a thinner head gasket IN ADDITION to CTR pistons.
[Modified by smerk, 5:06 PM 10/22/2001]
Old Oct 21, 2001 | 07:18 PM
Halo's Avatar
Default Re: GSR'S running CTR PISTONS? (smerk)
I have a complete set of 2000 ITR pistons and rods for sale for $280! If you have a GSR I can't imagine why you wouldn't want the ITR'S!
Old Oct 21, 2001 | 08:05 PM
Default Re: GSR'S running CTR PISTONS? (Halo)
He has ITR's already but he wants more compression and with CTR"S around 12.5:1 is what he'll get!! You can find that info anywhere. Thats why I was askin about the clearence issues.
Old Oct 21, 2001 | 08:27 PM
I don't want to give details. And "why bother?".. good question. Why bother posting anything at all? It's just another form of entertainment.
That must be this year's most retarded post I guess being ignorant is one of ricer's entertainment...lol!
Old Oct 22, 2001 | 05:37 AM
TRuST's Avatar
So, let me get this straight a CTR pistons in a stock GSR head gives you about a 12.5~:1 CR. What does a JDM ITR piston give in the same motor ?
Old Oct 22, 2001 | 07:03 AM
comptechgsr's Avatar
Default Re: GSR'S running CTR PISTONS? (TRuST)
jdm itr yields around 11.5-11.6 CR
Old Oct 22, 2001 | 07:11 AM
slowcivic's Avatar
New User
My GSR Block has been honed to 91.5mm. Is there a CTR Piston that will fit my application? Thanks for any information!
Old Oct 22, 2001 | 08:33 AM
flex97itr's Avatar
Default Re: GSR'S running CTR PISTONS? (slowcivic)
im sorry but i dont think 91.5mm is possible
Old Oct 22, 2001 | 08:52 AM
Night Kid's Avatar
New User
Default Re: GSR'S running CTR PISTONS? (flex97itr)
gsr w/ ctr pistons---is it streetable on pump gas? probably not right?
Old Oct 22, 2001 | 08:53 AM
eternal21's Avatar
Default Yes, it is...
...93 octane ALL the time.
Old Oct 22, 2001 | 10:01 AM
Rhetoric's Avatar
You sure its not 81.5mm? If its 81.5mm you can use the .25 over ctr pistons
Old Oct 22, 2001 | 04:31 PM
slowcivic's Avatar
New User
Default Re: GSR'S running CTR PISTONS? (G S R)
Yes, you are correct GSR, my mistake, I am running a 81.5mm bore not a 91.5mm bore. Thats good to know I can use the .25 over ctr pistons. Thanks again for pointing that out!
91 DA Revived
Jun 6, 2010 09:32 AM
what gsr
Jul 4, 2009 12:05 AM
SexyHatchie
Sep 24, 2007 12:13 PM
dwn-shift
Jun 24, 2003 07:19 PM
stretracr
Jun 26, 2001 06:16 PM
