Break-in for bearings?
Old Mar 19, 2004 | 04:36 PM
servion's Avatar
Default Break-in for bearings?
I want to verify that with new main and rod bearings, there is no "break-in" period when you rebuild a motor. Can anyone confirm?
Old Mar 19, 2004 | 04:54 PM
non-VTEC's Avatar
Default Re: Break-in for bearings? (servion)
the break in is usually for the rings only.......allthough it probably wouldent be a bad idea to take it easy on the engine for a couple hundred miles anyway just to be safe.....
Old Mar 19, 2004 | 08:09 PM
Kelly.'s Avatar
I've quit using this account
Default Re: Break-in for bearings? (non-VTEC)
That's what I've always thought.
I've got a good friend who spun a bearing BAD (its torn up, twisted into an s-shape) in his d16z6. He paid them to assemble it with eagle rods, SRP pistons and new OEM oil and water pumps (as well as all required machine work). Now, they're tellng him that they won't cover their work because he didn't wait to get on it until 1500 miles. I call major BS on that one, and I want to make sure you fellow h-t'ers will back me up
Old Mar 20, 2004 | 08:23 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: Break-in for bearings? (llewsirc)
sounds like whoever built it is full of sh*t..i stomp the hell out of my motors right after there built ..and no probs at all
Modified by bruceleeroy at 6:22 PM 3/20/2004
Old Mar 20, 2004 | 10:03 AM
zensoku207's Avatar
Theres a site on breaking in motors, the theory is about ring wear, the bearings arent a factor if the bottom end assembly is balanced which most are if put together right.
But the theory is drive it hard to break the rings in smoother, and change the oil after 20 miles to get rid of the ring shavings from the break in.
check it out
http://www.mototuneusa.com/break_in_secrets.htm
Old Mar 20, 2004 | 10:33 AM
servion's Avatar
Default Re: (zensoku207)
I agree with that method, too... that's what I've done with the motors I've built myself..... and I've alwyas thought that if clearances are right and assembly is done properly, bearings will not be a problem, regardless of how hard you beat on it.
aeon117
Jun 24, 2016 01:05 AM
rick_rabies
Sep 24, 2009 04:26 PM
Revi
Sep 26, 2006 06:16 AM
hOndafienD 04
Jan 13, 2005 05:28 PM
InfamousRS
Feb 13, 2002 07:42 PM
