94 V-tec... under-reving (idoling at 750rpm)!!
Old Mar 19, 2004 | 03:31 PM
andypandy's Avatar
Default 94 V-tec... under-reving (idoling at 750rpm)!!
HI! my vtec integ. is idoling at like 750rpm. i just did an oil change with an engine flush -no improvement-. I have also just added some injector cleaner to my fuel tank. Any suggestions?
Old Mar 19, 2004 | 03:34 PM
MyBigNut's Avatar
Default Re: 94 V-tec... under-reving (idoling at 750rpm)!! (andypandy)
Back out the flathead screw on the throttlebody until you get the rpm you want.
Old Mar 19, 2004 | 03:45 PM
Rayman's Avatar
750 is within spec anyways.
Old Mar 19, 2004 | 03:58 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: 94 V-tec... under-reving (Rayman)
That's not just within spec, that's exactly the spec. You should feel good about having a car that idles properly, the spec calls for 750 +/- 50 rpm so you're spot on.
Old Mar 19, 2004 | 04:14 PM
skunkintegra's Avatar
Default Re: 94 V-tec... under-reving (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">That's not just within spec, that's exactly the spec. You should feel good about having a car that idles properly, the spec calls for 750 +/- 50 rpm so you're spot on. </TD></TR></TABLE>
exactly what i was thinking!!
everytime i go to shut my car off i look at the VAFC, and wait until its in the 750rpm ballbark to shut her down!!
Old Mar 19, 2004 | 07:28 PM
-iLLuZioN-B18C1's Avatar
Default Re: 94 V-tec... under-reving (skunkintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunkintegra &raquo;</TD></TR><TR><TD CLASS="quote">
everytime i go to shut my car off i look at the VAFC, and wait until its in the 750rpm ballbark to shut her down!! </TD></TR></TABLE>
you do that everytime you get out? thats overkill.
Old Mar 19, 2004 | 07:44 PM
Default Re: 94 V-tec... under-reving (-iLLuZioN-B18C1)
ya-- ur right--- i dont do it everytime-- only if i think about it, or had just ran it hard :/
Old Mar 20, 2004 | 11:04 AM
frost_0ne's Avatar
adjust ur idle
Old Mar 20, 2004 | 12:03 PM
FastSS's Avatar
Default Re: 94 V-tec... under-reving (frost_0ne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frost_0ne &raquo;</TD></TR><TR><TD CLASS="quote">adjust ur idle
Did you even bother to read the rest of the posts or whats your deal?
His idle is spot on
Old Mar 20, 2004 | 06:30 PM
GSRGuy17's Avatar
Default Re: 94 V-tec... under-reving (FastSS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FastSS &raquo;</TD></TR><TR><TD CLASS="quote">
His idle is spot on</TD></TR></TABLE>
What he said... my '94 GS-R idles at 750rpm all day (unless it's hot and I have the A/C on... then it fluctuates sometimes)
Old Mar 20, 2004 | 06:59 PM
FastSS's Avatar
Default Re: 94 V-tec... under-reving (GSRGuy17)
I dont see that anywhere in the post, and besides, every car does that anyway... when the clutches on the AC compressor kick in, it bogs the car down a little bit... been so long since I ran the AC that I cant remember if it picks it up and idles higher with the AC on or stays lower...
Old Mar 20, 2004 | 08:05 PM
Quitripin's Avatar
i got a 95 gsr (obd1) so i can relate. At cold start your car is in open loop (when the ecu takes control of your car) at this point your car will idle about 1500 rpm or more. When your car reaches normal operation temperture is goes to a close loop, this is when your car began to idle 750 rpm 50+-. On your throttle body their is a idle screw I WOULD HIGHLY RECOMMEND THAT YOU DON'T TOUCH IT, it is adjusted by the factory. If you read the oem service manual it is not to be tampered! Your car sounds like its where it should be idle at.
k20o2o4civic
Apr 2, 2006 07:45 PM
1 2 NV
Jun 15, 2004 08:58 AM
sgT
Apr 21, 2003 08:07 AM
JDMPARTS4U
Sep 1, 2002 12:57 AM
