no hazards or turn signals ......
Old Mar 19, 2004 | 02:45 PM
ShAAdiiiNG's Avatar
Default no hazards or turn signals ......
i bought a 91 hf rolling chassis with out a harness. i pieced together a dx harness and then converted to obd-1. i went over this a million times and none of the fuses are blown and i just changed the underdash relay for the turn signals and nothing seems to work. dimmer switch and hazard switch are all hooked up and none of the bulbs seem to be blown. TIA
Old Mar 19, 2004 | 05:34 PM
Kasper.'s Avatar
Default Re: no hazards or turn signals ...... (ShAAdiiiNG)
I have to be honest if it was all stock and you just had no hazards or turn signals then I could prob. help you but since its all been done by yourself I have no idea how you ran everything and what might be a simple solution.
Do you get turn signals AT ALL like in the cluster or outside the vehicle.......Id say multi function switch if you havent already tried that.
Old Mar 19, 2004 | 05:47 PM
CimorelliCRX's Avatar
Default Re: no hazards or turn signals ...... (Kasper-EF8)
Your hazard switch is bad more likely. With the switch bad you will not get signals or hazards, its a common power and ground for the signals, and if there is a break in the switch it will not work.
Old Mar 19, 2004 | 05:49 PM
Kasper.'s Avatar
Default Re: no hazards or turn signals ...... (CimorelliCRX)
Took the words right outta my mouth....
Old Mar 19, 2004 | 10:31 PM
ShAAdiiiNG's Avatar
i have no signals what so ever, not even my cluster works. sorry i forgot to mention that.
Old Mar 21, 2004 | 02:02 PM
ShAAdiiiNG's Avatar
ttt
Old Mar 21, 2004 | 02:06 PM
Kasper.'s Avatar
Have you tried replacing either of the two me and the other guy mentioned?
GabeBellaflores
Jan 16, 2019 02:15 PM
Meraut
Mar 11, 2013 06:34 AM
smmagoo20
Nov 6, 2012 07:59 PM
Shocka1998LX
Nov 18, 2008 12:50 PM
EKhatch84
Aug 21, 2006 10:29 AM
