clutch pedal and engagement
Old Mar 19, 2004 | 01:41 PM
crxgator's Avatar
Default clutch pedal and engagement
well for some time my clutch pedal is way too high its like 2-3 inches higher than my brake pedal and it releases the clutch towards the top...i have tighted the bolt all the way down on the clutch pedal, and i think the cable is as far adjusted as it can go...any suggestions? do you think a new clutch cable will help? this was the same thing on my old crx that had a new act clutch in it...and i couldnt figure it out either...
Old Mar 19, 2004 | 01:46 PM
bryant's Avatar
Default Re: clutch pedal and engagement (crxgator)
The engagement point or just the position of the pedal?
Old Mar 19, 2004 | 01:48 PM
crxgator's Avatar
Default Re: clutch pedal and engagement (Bryant)
well both really...the pedal is stupid high and the engagement is at the top as well, its rather annoying...when i adjusted it to be tighter, the pedal feels not as hard to push down...
Old Mar 19, 2004 | 01:49 PM
7PSI CRX's Avatar
You adjust the pedal height with the bolt (under the dash) you mentioned.
As for the engagement point, to have it grab closer to the floor, you've got to "loosten" the cable. (turn the adjustment nut counter-clockwise, looking down at it)
Old Mar 19, 2004 | 01:55 PM
crxgator's Avatar
Default Re: clutch pedal and engagement (7PSI CRX)
lol, i thought tightening it would bring the pedal closer to the floor...
i guess ill loosen it and see what happens...
Old Mar 19, 2004 | 02:19 PM
EL Vap133's Avatar
It might be your cable, if all else fails try another cable and see if that works.
Old Mar 19, 2004 | 02:25 PM
crxgator's Avatar
Default Re: clutch pedal and engagement (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">It might be your cable, if all else fails try another cable and see if that works. </TD></TR></TABLE>
im kinda hoping its that in a sense...cause dam my pedal is higher than method man...
Old Mar 19, 2004 | 02:35 PM
EL Vap133's Avatar
LOL!! Mine took a few days to finally break. Is it hard to put it in gear?
Old Mar 19, 2004 | 02:44 PM
crxgator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">LOL!! Mine took a few days to finally break. Is it hard to put it in gear?</TD></TR></TABLE>
no, its like butta...
Old Mar 19, 2004 | 04:20 PM
ls_vtec_crx's Avatar
yeah my clutch pedal is whicked high too...compared to the gas and brake one....i gotta fix it ...thanks for the help guys
Old Mar 19, 2004 | 05:40 PM
Kasper.'s Avatar
Default Re: (ls_vtec_crx)
Have you replaced your clutch in the past???
If not it just sounds like your clutch is wearing out, your pedal position will change as wear and tear on the clutch affects its grabbing abilty, Im sure it still grabs fine and doesnt slip, but if the disk is getting thinner or your PP fingers are getting weaker it will take more pressure to apply it, remember that cable goes directly from your foot to the shift fork inside the bell housing, if it has less material there to grap the t/o bearing will move on the input shaft to keep close contact with that pressure plate, hence forth increasing stress/pull on the cable and pulling it higher.....
Now you should have slack in your pedal especially since its adjustable, but since you've already adjusted it so much it has prob. lost all that and your calbe is prob. about to snap.
Old Mar 19, 2004 | 06:47 PM
crxgator's Avatar
Default Re: (Kasper-EF8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kasper-EF8 &raquo;</TD></TR><TR><TD CLASS="quote">Have you replaced your clutch in the past???
Now you should have slack in your pedal especially since its adjustable, but since you've already adjusted it so much it has prob. lost all that and your calbe is prob. about to snap.</TD></TR></TABLE>
my old crx had the same problem and it had an ACT clutch in it...yeah i need to replace this soon, it doesnt slip at all though...but having 128k miles on it, doesnt help either...it still grabs pretty good...
Old Mar 21, 2004 | 09:30 AM
crxgator's Avatar
ok i figured it out today...i loosened the clutch cable...that lowered the engaging point...
and for some reason the bolt that ajdusts the clutch pedal also has a nut on it, so i took out the bolt and took off the nut and then put it to where i liked it...and now the clutch pedal is even with the brake pedal...
im happy right now for the little test drive...i just hope that the clutch doesnt slip because of where it engages...
89civicsiowner
May 24, 2009 05:29 PM
rapture
Dec 17, 2004 08:00 AM
FullMetalJacket
Mar 19, 2003 03:08 PM
See Are X
Apr 25, 2002 05:04 PM
