crx suspension question???
Old Mar 19, 2004 | 11:44 AM
benn2k's Avatar
Default crx suspension question???
hey whats up i just upgrade my suspensions from my 97 accord, so i had a extra set of coilovers now, so i started to put them on the rear shock of the crx and putthe wheels back on and didnt get a drop, why is that?? a.i.m benn2k@aol.com or a.i.m benn2k
Modified by benn2k at 9:20 PM 3/19/2004
Old Mar 19, 2004 | 12:10 PM
EL Vap133's Avatar
Default Re: crx suspension question??? (benn2k)
Maybe because you added stock coils?
Old Mar 19, 2004 | 12:21 PM
benn2k's Avatar
i had coilovers on my accord before i had when with a better setup, so i had put the coilover on the crx and did not get a drop, just did the rear so far , but it should still be dropped
Old Mar 19, 2004 | 12:43 PM
Nocturnal_Lude's Avatar
Default Re: (benn2k)
Maybe its because you using a setup for an accord....accord are a bit heavier then then our trusty ef's...possibly and I could be wrong, but possibly the springs are rated for a heavier rear end which on a crx would make the drop less substantial...try using crx coil overs...also, what kinda shocks are u using on the rex? stock?
Old Mar 19, 2004 | 12:45 PM
benn2k's Avatar
yeah stocks for now, so do u think i would be able to use them on the front??
Old Mar 19, 2004 | 11:52 PM
benn2k's Avatar
so it has to be the spring rate then, but would i be able to use them for the front??
Old Mar 20, 2004 | 07:48 PM
benn2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by benn2k &raquo;</TD></TR><TR><TD CLASS="quote"> hey whats up i just upgrade my suspensions from my 97 accord, so i had a extra set of coilovers now, so i started to put them on the rear shock of the crx and putthe wheels back on and didnt get a drop, why is that?? a.i.m benn2k@aol.com or a.i.m benn2k
Modified by benn2k at 9:20 PM 3/19/2004</TD></TR></TABLE>
Old Mar 25, 2004 | 02:57 PM
benn2k's Avatar
or what if i just take off the sleeve part and just use the spring for the rear?? my friend said the the front will work since its heaver from the motor
mudpuppy4life
Dec 9, 2013 05:29 AM
LsVtec08
Suspension & Brakes
Dec 10, 2010 08:04 PM
Dirty_SL8
Oct 8, 2009 05:46 PM
VeilSide_Mas
36
Mar 31, 2006 10:32 AM
