speedometer needle?
Old Mar 19, 2004 | 10:12 AM
At_oNe315's Avatar
Default speedometer needle?
I've searched and obviously it is not a good idea to ask about rolling the odometer back, so all I need to know is this- how to remove speedo needle w/o busting it? I will figure out the rest after I get the needle off. Thanx-@1
Old Mar 19, 2004 | 10:25 AM
tominos's Avatar
Default Re: speedometer needle? (At_oNe315)
it's pretty hard to do. maybe there is a special tool for it, but:
if you use the back end of a fork, the part that curves upwards, and try to slide it under the speedo needle, hopefully it'll pop off. if not, you just bought yourself another speedo gl man
Old Mar 20, 2004 | 10:15 AM
At_oNe315's Avatar
anyone else?
Old Mar 20, 2004 | 12:30 PM
doublejz's Avatar
um what are you attempting to do?
to roll it back or forward or whatever, use a sewing needle and turn the numbers with it.
if your gonna put on white face gauges just slide em over.
I haven't had a reason to remove the needles, theres usually a way around removing them.
Old Mar 22, 2004 | 09:03 AM
At_oNe315's Avatar
Default Re: speedometer needle? (doublejz)
sewing needle? could you elaborate?
chelt_scene
12
Jul 5, 2009 07:26 PM
ac_attak
Sep 16, 2006 11:56 AM
ekdriven
Mar 8, 2005 08:00 AM
iam7head
Sep 25, 2002 07:05 AM
Attoir
Jun 24, 2002 09:31 PM
