Lightweight 15" wheels?
Does anyone know of really lightweight wheels other than the TE37 that are available in 7 inch width? It seems like everyone is only making theirs in 6.5.
SSR competitons
15X6.5 = 8.6lbs
15x7 = 9.2lbs
Spoon Sport SW388
15x6.5 = 8.6lbs
Racing Hart CP-035
15x6.5 = 8.6lbs
15x7 = 9.4lbs
Desmond Rega Master EVO (Forged)
15x6.5 = 8.6lbs
15X6.5 = 8.6lbs
15x7 = 9.2lbs
Spoon Sport SW388
15x6.5 = 8.6lbs
Racing Hart CP-035
15x6.5 = 8.6lbs
15x7 = 9.4lbs
15x6.5 = 8.6lbs
That's right... I forgot about the SSR Competitions. Thanks for reminding me... I think those will be one of my first choices.
Better fit for 225 rubber.
What are the advantages of 15x7 compared to 15x6.5?
SSRs in 15x7.5. I don't think there is a better wheel for our car in any size at any price. I know someone who used to race Civics years ago and he did some testing with different wheel sizes. He ended up running 185 width tires on 8" rims. I think tire width was controlled.
It may be specific to the tires and car he was running with, but I think for the most part wheel width is MUCH more important than wheel weight, and the wider the better. That's why I never understood why people like Spoons. They might be okay with the stock tire size, but they pinch way too much when you move up a size or three.
I don't think you could end up with a dangerous combo. Maybe the 185 on an 8" is a little extreme, but 7.5" is 191mm. So even if you used a 195 width tire with a 7.5" rim you'd be square. I don't believe there is any problem with using a wider rim. I think almost everybody with an EG or a DC running Solo I has moved up to using 225s. I wouldn't even bother going back to 205s, unless you're really worried about bending the lip on the rear.
Here's a pic of when I was using 205s on a 7" rim:
It looked roughly square. Here are the same wheels with 225s:
I also used those wheels through four winters with 195s. Aside from a little extra dartiness which can mostly be attributed to the 38 offset they worked perfect. In fact I won my class at a regional Solo II with those tires! Hakkapelliittaaas rock!
Really there's no point to not going with a 225 tire, especially since the Kumho 225/45s are coming out. With the 7.5" SSRs you'd have the ultimate wheel/tire combination you can possibly fit on your car!
[Modified by B18C5, 5:23 PM 10/21/2001]
[Modified by B18C5, 5:25 PM 10/21/2001]
PerformanceDesigns
93
Dec 30, 2007 11:02 AM
