Braking Problem coming down from high speeds
Old Mar 19, 2004 | 08:19 AM
tommymoose's Avatar
Default Braking Problem coming down from high speeds
When I'm slowing down somewhat quickly from being above about 80 mph, the steering wheel vibrates much harder than what it normally would. I was wondering if anybody knows if this is normal or if there is a problem anywhere. Could it possibly be slightly warped discs? I have a 96 LX Accord. Thanks for any help.
Old Mar 19, 2004 | 08:37 AM
skabone's Avatar
Default Re: Braking Problem coming down from high speeds (tommymoose)
sounds like warped rotors. get them machined down, or some new brembo blanks if you want an OEM replacement.
Old Mar 19, 2004 | 08:53 AM
jwogen1's Avatar
what kind of pads are you using--may be a problem as well
Old Mar 19, 2004 | 09:31 AM
.bagged's Avatar
Default Re: Braking Problem coming down from high speeds (jwogen1)
Could be the rotors like skabone said or like J-dog said check your pads sometimes you get almost flat spots in the pad which can cause the steering wheels to shake..is the petal shaking too...If not it could be tires out of balance too
Old Mar 19, 2004 | 09:37 AM
The_Todd's Avatar
Farts in the shower
Default Re: Braking Problem coming down from high speeds (baGged93aCcord)
Exactly, check your fluid levels, pads and rotors....if its not any of those rotate and or balance your tires
Old Mar 20, 2004 | 05:16 PM
tommymoose's Avatar
Default Re: Braking Problem coming down from high speeds (VRDrvr)
I've got the genuine honda replacement rotors and pads, so i'll make sure to check the fluid and maybe add a big(ger) break kit to the to-do list... thanks alot
Old Mar 20, 2004 | 07:12 PM
spankey167's Avatar
It sounds liek warped rotors which would lead to uneven wearing of brake pads as well. So you might want to replace the pads the same time you are replacing/resurfacing the rotors.
Extreez
Aug 19, 2006 07:48 AM
53JDMDC2
May 28, 2005 04:14 PM
Jer'rome
May 1, 2005 10:26 AM
Jaydeep
17
Feb 7, 2005 02:41 PM
zseeanz
Mar 24, 2004 02:41 PM
