moisture in head lights - better process for clearing it up long term?
Old Mar 19, 2004 | 08:14 AM
Xymox007's Avatar
Default moisture in head lights - better process for clearing it up long term?
first things first..
1) i searched and got some info. thanks search feature.
2) i tried the hair dryer method. worked for one day.
3) must i take the entire front bumper off to remove the lenses?
4) is there a better process for clearing up the moisture?
thanks in advance.
Old Mar 19, 2004 | 08:18 AM
timmy8151's Avatar
Default Re: moisture in head lights - better process for clearing it up long term? (Xymox007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xymox007 &raquo;</TD></TR><TR><TD CLASS="quote">first things first..
thanks in advance. </TD></TR></TABLE>
Yes, you'll have to remove the bumper. The most common method of fixing this problem is to bake the headlights so you can remove the lens. Then you just reseal the headlights with some silicone sealant. I've also heard of people drilling a small drain hole, but haven't done it myself.
Also, check for cracks on your mounting tabs. I had a leak and thought it was my seal, but it turned out I had crack on my tabs. I just sealed it up with some epoxy.
Old Mar 19, 2004 | 08:20 AM
MAV3RiCK478's Avatar
don't bake them, use a hair dryer or heat gun. less chance of melting the lights.
Old Mar 19, 2004 | 08:33 AM
timmy8151's Avatar
Default Re: moisture in head lights - better process for clearing it up long term? (MAV3RiCK478)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAV3RiCK478 &raquo;</TD></TR><TR><TD CLASS="quote">don't bake them, use a hair dryer or heat gun. less chance of melting the lights.</TD></TR></TABLE>
Heat gun and hair dryer is a temporary solution. Also, baking the headlights wont melt them, if you set it at a low temp.
Old Mar 19, 2004 | 08:44 AM
Xymox007's Avatar
Default Re: moisture in head lights - better process for clearing it up long term? (timmy8151)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, you'll have to remove the bumper..</TD></TR></TABLE>
Bugga. That's going to take some time. How much is involved with taking off the bumper? I didn't want this to get real complicated.
Thanks.
Old Mar 19, 2004 | 08:51 AM
timmy8151's Avatar
Taking out the bumper is pretty easy and only takes a couple of minutes. However, there are 2 hidden bolts that you can only access by removing part of the wheel lining.
Old Mar 19, 2004 | 08:55 AM
Xymox007's Avatar
Ah, good to know. Saves me the trouble (and chance) of forcing the bumper and breaking it. I really gotta get a house, garage, and better tools.
It seems as soon as I fix a problem with my car and smile about it, something else springs up.
Old Mar 19, 2004 | 09:09 AM
BolivianDc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xymox007 &raquo;</TD></TR><TR><TD CLASS="quote">It seems as soon as I fix a problem with my car and smile about it, something else springs up. </TD></TR></TABLE>
amen to that
at least they arn't mistubishis
Old Mar 19, 2004 | 01:42 PM
Xymox007's Avatar
Default Re: moisture in head lights - better process for clearing it up long term? (BolivianDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BolivianDc2 &raquo;</TD></TR><TR><TD CLASS="quote">at least they arn't mistubishis </TD></TR></TABLE>
Or Volkswagens (coming from a guy that had 4).
lilman4o8
Aug 29, 2007 05:23 PM
ghg78
Nov 11, 2005 05:19 PM
eymnewdc4
Jan 29, 2005 08:53 PM
CivicSiRracer69
Mar 15, 2004 07:36 PM
CardDealer
Aug 11, 2002 05:24 AM
