96 Accord ABS Advice
Old Mar 19, 2004 | 07:41 AM
regiment1's Avatar
Default 96 Accord ABS Advice
Recently, I have heard a loud whining/whirring from the driver's side front corner of the engine compartment when starting my '96 Accord EX (151k mileage). It only happens in cold weather, and lasts about 45 seconds. I can feel a vibration in the brake pedal at the same time. In all conditions, the ABS light comes on about 45 seconds after I start the vechicle.
The dealer has advised that the ABS accumulator and modulator be replaced, due to leakage. Another tech that I have informally asked thought it would be rare to have to replace both, and that it would most likely only require an accumulator.
So, I have some questions:
- Is there any point in replacing only the accumulator to see if it solves the problem?
- If I replace the modulator, are used modulators generally reliable?
- Can I just get by if I refill the ABS reservoir occasionally?
Any advice or help would be greatly appreciated! Thank you!
Old Mar 22, 2004 | 08:38 AM
regiment1's Avatar
Default Re: 96 Accord ABS Advice (regiment1)
I'm just bumping this in the hope someone can help out.
Thanks!
Old Mar 22, 2004 | 09:05 AM
Mike813's Avatar
if you do a search on ABS, someone posted a thread on how to fix the leak WAY lower than what dealers will want... i think he spent less than 3$'s for parts and fixed his problem... it has links to the diagram and the procedure... hope you find it!
Old Mar 23, 2004 | 10:50 AM
regiment1's Avatar
Default Re: 96 Accord ABS Advice (Mike813)
Found it! Thanks for the help.
Old Mar 23, 2004 | 11:15 AM
RotaryBzzzz's Avatar
Did someone say A-B-S?
wagontrain
Jul 13, 2012 01:36 PM
honda_kid42
Aug 15, 2010 12:17 PM
moepeppa
Aug 28, 2003 06:28 PM
