what to use to clean tranny and block???
Old Mar 19, 2004 | 04:19 AM
sircrxracer's Avatar
Default what to use to clean tranny and block???
I'm trying to clean the tranny and block what do you guys use to clean all the grim and **** of them???? what worked for you? any pics before and after. TIA Rob
Old Mar 19, 2004 | 05:15 AM
^Sammy]!.'s Avatar
From: 9/11/01 WTC Never Forget, United States Of America
Default Re: what to use to clean tranny and block??? (sircrxracer)
Use Gumout engine cleaner its good ****
Old Mar 19, 2004 | 05:31 AM
ImportsCRX's Avatar
i use Gunk Engine Brite.
Old Mar 19, 2004 | 05:32 AM
GreenMachineRex's Avatar
Default Re: (ImportsCRX)
i posted this on another site. every one says " simple green"
Old Mar 19, 2004 | 05:40 AM
Monty's Avatar
Default Re: what to use to clean tranny and block??? (MR.RED'89)
Gunk, and brake cleaner did it for me... Simple green after the install...
Old Mar 19, 2004 | 07:39 AM
manson's Avatar
Default Re: what to use to clean tranny and block??? (Monty)
i've used gunk...that **** sucks.
i usually use brake cleaner or simple green... depends on what the brake cleaner can get on.
Old Mar 19, 2004 | 08:04 AM
Project_ED8's Avatar
gunk is ok. i use some 78cent walmart engine degreaser or simple green. spray some on and let it sit there for awhile...then scrub away...and then hose it down with water. repeat process as many times as ya want! good luck.
Old Mar 19, 2004 | 09:23 AM
EL Vap133's Avatar
I just use Simple Green, works good! I used to use that gunk stuff but it smells pretty bad and it can discolor things.
Old Mar 19, 2004 | 10:26 AM
Rywire's Avatar
Default Re: what to use to clean tranny and block??? (EL Vap133)
I heard there was 2 kinds of simple green, anyone... Ryan
Old Mar 19, 2004 | 12:14 PM
EL Vap133's Avatar
Default Re: what to use to clean tranny and block??? (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">I heard there was 2 kinds of simple green, anyone... Ryan</TD></TR></TABLE>
I've only see one. Just try your local auto parts.
Old Mar 19, 2004 | 10:54 PM
Rywire's Avatar
gracias
Old Mar 20, 2004 | 05:19 AM
Kasper.'s Avatar
I put my engines/trannys in the steam cleaner at work ......lol Im so spoiled....
Otherwise yeah Id use simple green or anytime of degreaser and a sos pad then go over it with a reg. towel later.
Old Mar 20, 2004 | 06:57 AM
2point2's Avatar
Old Mar 20, 2004 | 07:29 AM
-16V-'s Avatar
Default Re: what to use to clean tranny and block??? (2point2)
I was told simple green too. Untill i saw a post some where, that its not good for aluminum...
Thats weird.
Old Mar 20, 2004 | 09:47 AM
JCracer723's Avatar
Default Re: what to use to clean tranny and block??? (-16V-)
any kind of dregreaser should work .. the key its on scrubin the **** out of them ... yes you are going to get tired and fustraded but it would be worth it ... use some kind of thin wire brush.. to brush of the thick grease
good luck
Old Mar 20, 2004 | 09:59 AM
POE's Avatar
POE
simple green for me baby!
Old Mar 20, 2004 | 10:00 AM
B2FiNiTY's Avatar
Default Re: (Vtecin94dx)
Gunk foaming!
Old Mar 20, 2004 | 10:09 AM
Kyo Babic's Avatar
Default Re: (B2FiNiTY)
http://www.fourthgenhatch.com/index2.html he has a pretty good write up on engine cleaning
Old Mar 20, 2004 | 10:49 AM
JCracer723's Avatar
Default Re: (Kyo Babic)
wow that guy just sprayed water all over the engine bay without covering anything.. its that safe???
Old Mar 20, 2004 | 11:05 AM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -16V- &raquo;</TD></TR><TR><TD CLASS="quote">I was told simple green too. Untill i saw a post some where, that its not good for aluminum...
Thats weird.</TD></TR></TABLE>
The one for automotive purposes is perfectly safe.
Old Mar 20, 2004 | 11:31 AM
90JPRCRX's Avatar
Smells like Tuna
not to hijack your thread but if everybody could post before clean and after clean pictures and tell us what you used
i think that would be much more informative
Old Mar 20, 2004 | 11:39 AM
Default Re: what to use to clean tranny and block??? (88JPRCRX)
Simple green
Old Mar 20, 2004 | 11:50 AM
90JPRCRX's Avatar
Smells like Tuna
Default Re: what to use to clean tranny and block??? (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
Simple green </TD></TR></TABLE>
simple green turned your D series into a B series WOW..........i gotta get me some of that
Old Mar 20, 2004 | 11:51 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88JPRCRX &raquo;</TD></TR><TR><TD CLASS="quote">
simple green turned your D series into a B series WOW..........i gotta get me some of that</TD></TR></TABLE>
I was thinking of putting some type of caption like that.
Old Mar 20, 2004 | 06:34 PM
escocrx's Avatar
high pressure washer is what i use.
no soap. no need at 1800psi
