ZC Dohc Cam Gears (searched)
Old Mar 19, 2004 | 04:00 AM
qwksi1's Avatar
Default ZC Dohc Cam Gears (searched)
I have a Crx that I bought with AEM Cam gears on a Dohc ZC. They are saet at zero degrees, but my friend told me they aren't made for the motor, and are actually from an B series. Anyone tell me how far off they are from the true Zero setting, or approx. where I need to set them to get back to zero. The car pulls good now, but it seems to have some valleys in the power curve... let me know if anyone knows?
Old Mar 19, 2004 | 04:50 AM
spiceisler's Avatar
Default Re: ZC Dohc Cam Gears (qwksi1)
Check with TJ
Old Mar 19, 2004 | 04:54 AM
redzcstandardhatch's Avatar
something different
i'm pretty sure the timing should be correct, my srr ones were perfect.
Old Mar 19, 2004 | 05:55 AM
1point5CRX's Avatar
Default Re: (redzcstandardhatch)
i know its off subjext a bit but i see your sig has a stock gs-t, which is faster? gs-t or crx?
Old Mar 19, 2004 | 06:40 AM
jlicrx's Avatar
whether you are out of time depends on how they were installed - marks on the B16 gears are one tooth off from the ZC gears - if this was taken into account when they were installed, they would be right
Old Mar 20, 2004 | 10:04 AM
qwksi1's Avatar
Default Re: ZC Dohc Cam Gears (jlicrx)
How would it run if it were one tooth off? Its runs strong.
Old Mar 24, 2004 | 11:27 AM
CRXzcLJH's Avatar
dude you can run like 10 degrees off, its called advancing or retarding the timing i doubt you would even notice if someone broke into your car at night and set your timing back to 0
90civichbsi
Aug 27, 2003 07:58 PM
88ZCRX
Sep 30, 2002 09:28 AM
gregv
Jul 16, 2002 05:42 PM
little red crx
Jul 10, 2002 12:24 PM
REDBARON
12
Dec 3, 2001 04:00 PM
