Pic Request: Neuspeed Front STB on a 4th Gen.
can someone post a pic of a 4th gen accord w/ a 4point neuspeed front stb installed? i picked up a used one recently and it doesnt mount up to both of the upper control arm points like ive seen on other applications like integras, 5th gen accords, etc. its seems like itll mount to one of the uca's and one of the shock mounts. is that right?? this is the only pic i could find but i cant tell where the rear points are mounted to:
You are correct sah..where the upper a-arm mounts into the engine cmt. is where you mount too..If you have ever put in a camber kit..thats where is connects it will be a 17mm..and make sure the car is jacked up in the front to relieve chassis strain then put the tower bar on and lower then tighten..
Youve got it in the right spot. I just checked on my car.
BTW - would anybody like to by one of these, I can no longer use mine with an H22, exact same bar as the one pictured, perfect condition, make offer.
