Raising compression
Old Oct 20, 2001 | 06:13 PM
Zerograv's Avatar
New User
Default Raising compression
I'm planning to raise the compression of my 2000 Civic Si to 11.5 from 10.2 What kind of power/torque gains should I expect? Will I get power starting from idle to redline? Or from midrange to redline and none whatsoever at idle to low 2K rpm's? Thanks
Old Oct 21, 2001 | 05:39 AM
Red Civic T's Avatar
New User
Default Re: Raising compression (Zerograv)
Prob 8-10 hp WHEN you dial the cams as their timing will be affected. Torque def improves (I run ~11.5:1) but you will still not get v8 pull low down. But def. will notice it. You may have to dial back the "electrical" timing, that is retard it slightly or you will get knock....
Old Oct 21, 2001 | 08:14 PM
Muglit's Avatar
New User
Default Re: Raising compression (Red Civic T)
I believe the standard equation is 4% for each point of increase, and this for the entire rev-band.
Old Oct 25, 2001 | 03:02 PM
Zerograv's Avatar
New User
Default Re: Raising compression (Muglit)
Thanks very much guys. I'll look into it.
koczeka
Mar 27, 2007 12:42 AM
KeyserSoze
Oct 20, 2005 08:36 PM
nochance
Oct 7, 2005 09:10 AM
austrian type-R
Jan 14, 2002 10:32 AM
Crossett
Dec 3, 2001 06:41 AM
