How to make it so u can go over redline and....
Old Mar 18, 2004 | 05:38 PM
BobGnarly's Avatar
Default How to make it so u can go over redline and....
ow can i make my 99 GSR go over redline without it cutting my fuel. Also does anyone know were i can get new sparkplug wires and sparkplugs for my 99 GSR. Thanx
Old Mar 18, 2004 | 05:41 PM
the.hamburglar's Avatar
Default Re: How to make it so u can go over redline and.... (Ultraroms)
yes plugs where? they are not an easy find, looks like ill be doing a special order
Old Mar 18, 2004 | 05:42 PM
xteg95's Avatar
is there a reason you ened to go over redline? if your motor isnt setup for it you can seriously damage it...for plugs and wires check out http://www.groupbuycenter.com they always have NGK plugs on sale.
Old Mar 18, 2004 | 05:43 PM
Kendall's Avatar
Why do you want to? The GSR stops making power well before redline, revving higher without serious modification only means increased wear on the engine. As for plugs and wires, the OEM wires are about the best that you can get. You can pick up NGK Iridium plugs at Advance Auto Parts, but I'd rather have Denso's.
Old Mar 18, 2004 | 05:45 PM
BobGnarly's Avatar
Default Re: (Kendall)
when is the perfect time to shift on a gsr if ur racing?
Old Mar 18, 2004 | 06:03 PM
ThePro's Avatar
Default Re: (Ultraroms)
Well, this is a loaded question..
But I won't hit it.
My dyno said I stopped making power at 7600 RPMs so I'd shift around there. But really, get dyno'd and check for your specific car because it varies with each engine.
Old Mar 18, 2004 | 06:22 PM
BobGnarly's Avatar
Default Re: (ThePro)
anyone know a place near laguna niguel that can dyno my car? this is SO cal
1s1cdc2
Jul 30, 2010 10:15 PM
rotascircuit
Dec 22, 2007 05:49 PM
Loil
Oct 13, 2004 03:01 PM
knowtomorrow3001
Dec 31, 2003 12:59 PM
