I recieved a code from the ECU.... what's it mean?
Old Mar 18, 2004 | 03:52 PM
nexus da9's Avatar
Default I recieved a code from the ECU.... what's it mean?
ok guys, i finally got the code.... i got the code 13.... what's that?
Old Mar 18, 2004 | 04:01 PM
Dased530's Avatar
Default Re: I recieved a code from the ECU.... what's it mean? (nexus da9)
I'm like 200% sure there's a post that lists all the ECU codes for your DA search and you will find it
Old Mar 18, 2004 | 04:04 PM
Dased530's Avatar
Default Re: I recieved a code from the ECU.... what's it mean? (Dased530)
https://honda-tech.com/zerothread?id=762999
Look what I found under archived ecu code 13
Old Mar 18, 2004 | 05:25 PM
xenocron's Avatar
Code 13 is PA sensor
Old Mar 18, 2004 | 08:49 PM
nexus da9's Avatar
Default Re: I recieved a code from the ECU.... what's it mean? (xenocron)
what's a PA sensor?
Old Mar 19, 2004 | 09:16 AM
xenocron's Avatar
measures barometric pressure
Old Mar 19, 2004 | 10:01 AM
nexus da9's Avatar
what could i do to fix it?
Old Mar 19, 2004 | 10:53 AM
stasi's Avatar
Is the car stock?
Old Mar 19, 2004 | 07:45 PM
xenocron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nexus da9 &raquo;</TD></TR><TR><TD CLASS="quote">what could i do to fix it?</TD></TR></TABLE>
Search...
And because im nice, da's have two version of PR4 ECU's (i am assuming you are running a PR4)...the 90 model comes with an external PA (not inside the ECU)...therefore 90 model integra's have an external PA somewhere in the engine bay i believe.
91 versions have an internal PA sensor in the PR4 ECU...
Have you recently switched ECU's or anything else? OR did this code just start appearing?
nolicense526
Jun 27, 2007 07:02 PM
sohc90rex
Jul 13, 2006 12:41 PM
lscrxhf
Jul 4, 2006 08:08 AM
White Lightnin
Jun 28, 2002 09:15 AM
