I put regular unleaded gasoline in my GSR is it bad?
Old Mar 18, 2004 | 02:52 PM
BobGnarly's Avatar
Default I put regular unleaded gasoline in my GSR is it bad?
just wondering on the dash it says premium unleaded only but i decided to see what mileage i get with normal but then i saw that i was like **** i forgot. Anyone know it its bad?
99 GSR
Old Mar 18, 2004 | 02:59 PM
Smeeg Heed's Avatar
Default Re: I put regular unleaded gasoline in my GSR is it bad? (Ultraroms)
GS-R has a pretty high compression engine. It needs high octane gas. A tank or two isn't gonna hurt it or anything but the knock sensor is gonna have to retard the timing so you'll lose a bit of power and over time it would be bad for the engine.
Use premium.
Old Mar 18, 2004 | 03:01 PM
BobGnarly's Avatar
Default Re: I put regular unleaded gasoline in my GSR is it bad? (NS98GSR)
ok i jsut did it once jsut wanted to make sure it wouldnt blow my engine up.
Old Mar 18, 2004 | 03:28 PM
ThePro's Avatar
Now I'm talking out my rear here, but after that tank you may want to reset your ECU incase it actually retarded your timing to prevent pinging..
<----- Who has done this when he swapped the GS-R engine in. "Oops! It's still full of LS gas (87 octane)!"
Old Mar 18, 2004 | 03:50 PM
Khmai_guy's Avatar
oh **** I didn't even know that i swapped a b18c in my ls about 3000 miles ago and been puttin in 89. Most definitely after this tank put in 91, but you think I did any damage with my engine?
Old Mar 18, 2004 | 04:06 PM
ekb18cCivic's Avatar
Default Re: I put regular unleaded gasoline in my GSR is it bad? (Khmer_DC2)
throw some octane booster in the tank... and ake sure next time you dont forget to fill up on premium
Old Mar 18, 2004 | 04:14 PM
Honda Hick's Avatar
It won't hurt anything really. My buddy's dad bought a '95 GSR with 120k miles from the original owner. The owner only used regular gas. They weren't very hard on the car, I'm sure that helped not hurt anything. When he bought it he threw 93 (haha CA ) octane in and reset the ECU and it ran great.
Old Mar 18, 2004 | 05:09 PM
BobGnarly's Avatar
Default Re: I put regular unleaded gasoline in my GSR is it bad? (Honda Hick)
How do u reset the ECU
Old Mar 18, 2004 | 05:12 PM
AznJohn33's Avatar
ooh ooh i get to say it first.
SEARCH.
If you search under "reset ecu" u'll get like 100 hits, i swear.
anyways, u can reset the ecu by the disconnect-the-battery method or the mess-with-the-fuses method. search, and take your pick.
Old Mar 18, 2004 | 05:38 PM
BobGnarly's Avatar
Default Re: I put regular unleaded gasoline in my GSR is it bad? (AznJohn33)
ya right when i pressed back i saw reset the ecu lol
thanx anyways
sushii_X
Oct 25, 2011 07:47 PM
mickey513
Apr 16, 2004 10:15 PM
B18 CYA
Dec 3, 2003 01:03 PM
GatchamanGSR95
Jan 9, 2002 12:08 PM
arete213
Oct 14, 2001 10:42 AM
